Keep your steed gleaming like new !!!
Home Forums Bike Preparation Tips Bike Preparation Tips Keep your steed gleaming like new !!!
This topic contains 62 replies, has 0 voices, and was last updated by  craig evans 13 years, 8 months ago.
Viewing 3 posts - 61 through 63 (of 63 total)
  • #224997
    jeff
    Boony,
    The reason you bike is a dust magnet is a result of static buildup!!!
    This occurs from rubbing of the plastics.
    I detailed for over 10 years and there is an easy cure.
    After you have finished polishing and have removed all residue, spray your bike with water from an atomiser (water sprayer) with clean cold water and simply wipe over with a good quality, clean chamois.
    This will remove the static which in turn stops the dust build up!!!
    Word of warning though, don’t try this trick if you have used Gold Class polish, as it will certainly cause “water spotting” .
    As for the silicon spray to help prevent mud and dust sticking like a bitch, any of the non stick cooking sprays will do the same job for alot less money and won’t effect your brake discs/pads if they accidently get sprayed.
    Hope this helps
    P.S. If you get annoyed by the white residue that Wet Look leaves around edges of your decals etc, change to NXT as it does not dry “white”.
    #224998
    Cheers champ.
    #224999
    craig evans
    thanx xt600 im ging to try ur surguestions
