KTM 300 EXC-e Jetting Spec
Home Forums KTM Bikes KTM Bikes KTM 300 EXC-e Jetting Spec
This topic contains 10 replies, has 0 voices, and was last updated by  Paul Gidley 16 years, 11 months ago.
  • #95107
    Hey Guys
    Anyone out there got the ‘heads up’ on half decent jetting spec’s for the 2009 KTM300, as KTM factory settings supplied are very average!
    Dr D
    #108111
    Give this a go if your game Mate
    N3CH Needle in clip #3 –its from a 2003 250 SX
    38 pilot
    168 main jet
    Air screw at 1 ¼ turns out
    Should rip your arms out Man
    Enjoy
    #108135
    Jason
    Dr D
    I have messed around with my bike and since November 2008 have enjoyed the following JD Jetting (about $140 and 5 minutes effort).
    Main Jet – 162
    Idle/Pilot Jet – standard
    Jet Needle – red
    Clip – 3rd from starting position
    Air – 1 complete turn only
    Delivers smoooooth power / torque and revs clean right off the bottom. (Note – all the standard weazel word disclaimers should apply here should you hate it) :silly:
    Goodluck
    #127825
    Hi Guys
    This what has have tested and have been running for some weeks now with know problems.
    Pilot 38
    JD Red neddle on clip #2
    Main jet 158
    Air Srew at 1.5 turns out
    It feels very smooth all the way through the rev range
    Dr D
    #127855
    Jason
    Sounds good – but would be interested in what fuel mix ratio are you using? As I recall, JD RED needle (runs leaner) and BLUE (richer) and JD recommend BLUE with clip in position 2 and air mix at 1.5 turns.
    I run fuel at 40:1 so with a RED needle I have the clip at position 3 (richens/increases fuel)and it only needs 1 turn of the idle jet. What impressed me most with this setting was the extra fuel range I got for each ride.
    #127877
    Hi Fezza
    I run it at 50:1 on motorex and my range two weeks ago was 6.5 litres for about the 100kms if you add up my jet range it’s 38 and 158 wich is 196 and JD jetting kit requested 195 at sealevel up to 6000 ft .So i’m alittle on the rich side but it go real well all the way around single trail and the open fire trail as well.
    Dr D
    #127879
    Jason
    Dr D
    Sounds like you are well sorted. The economy you are getting is second to none, you must be happy with that!
    ps. you’re not Dr Dan on DBW are you?
    #127898
    Hey Fezza
    No Dr D is Chris warwick a friend of crash and trailboss, give this jetting ago and see if can feel the change in the power, also using the yellow spring on Powervalve
    #127902
    Jason
    Cool…I will have a crack at the different settings, that is one of the great things about the 3hungee, you can play with so many settings relatively easily. Unfortunately the only thing holding me back is the 8 weeks needed until I can ride again. I was a bit ambitious at the Kowen Rally on the weekend and binned the bike hard, fracturing both my arm and shoulder. Stupid really I still had another loop to complete and some really cool rides set-up. The next ride can’t come quick enough.
    #128632
    No good mate, rest well, PDS get ya?
    Paul Gidley
    I have a 2008, but I understand its the same donk as the 09. I have the following set up for riding mainly below 1500 ft: –
    Stock needle – NZ2J ( or is it N2ZJ?) – 3rd clip
    Air screw 1.5 turns out
    main 160
    pilot 35
    Get about 110 k from a tank, is responsive throughout the rev range, mix at 50:1 (full synthetic).
