KTM 300 pipe repairs before & after photos
This topic contains 17 replies, has 0 voices, and was last updated by  Scott Hanley 13 years, 10 months ago.
  • #101394
    Marcus
    Pipe repaired with a little heat and compressed air :laugh:
    #221699
    nice work :)
    saved ya $500 for a newy from Austria :laugh:
    #221707
    Awesome job mate! I probably would have just thrown it out but it seem you got it back to a pretty good shape. Does it line up well each end still?
    #221700
    Marcus
    Hey Nato,
    Yep slipped straight back on!
    #221785
    Great job Cramusic
    How did you block the ends?
    I was always going to make some special jigs with one end having a car v/v
    Seeya on our next ride and we can do it all again. :ohmy: 👿 :woohoo:
    MARTIN TWINE
    Good work there mate, certainly saves you a few dollars.
    Galey would be interested in this.
    Catch up soon
    Marty
    #221791
    Adrian Gale
    Noted Marty450.
    Great job Mick. I have one in the shed for you to do! From a Murph ride as well. I hope the 300 is back in showroom condition. If only I had a gas axe.
    #221701
    Marcus
    Here is the setup!
    I cant take credit for it my bro is a fitter and spun it up at work :laugh:
    #221702
    Marcus
    [attachment=3415]IMG_6123.JPG[/attachment]
    #222027
    Wow that’s fancy. You can’t muck around with this stuff though can you. Easy to get injured or killed. Good stuff!
    Ah one more thing, if that’s the stock pipe keep a close eye on that spot. Has a tendency to start cracking there and open up.
    #222029
    That is elaberate, Marcus
    If I ever get around to making something for my son it wont be that flash. :whistle:
    Thanks for the peek
    don t be a softcock axel they got a regulater on there .top setup i reckon
    #221703
    Scott Hanley
    Nice set up. What pressure did you put in it?
    Scott
    #221704
    Marcus
    Thanks,
    50 psi will get em out on a stock pipe with some heat and your looking upto 70 psi with heat on a gnarly pipe.
    And of course the amount of pressure depends on the size of dent.
    Just start low and work your way up till it pops. :side:
    Also the relief valve is set to 70 psi so no blow outs! :laugh:
    #222031
    Well yes on that setup there is. What I meant is I’ve seen other do this without anything of the sort so I’m pretty sure blowing out the cork at then end at high pressure will earn them a hole in the head.
    I’ll be trying mine in the freezer one day, now I’ve got a deep freezer….
