KTM 450EXC Adventure Conversion
Home Forums The Adventure Moto Riding Forum Dual Sporting / Adventure Riding KTM 450EXC Adventure Conversion
This topic contains 52 replies, has 0 voices, and was last updated by  Harold Withington 11 years, 11 months ago.
Viewing 15 posts - 1 through 15 (of 57 total)
  • #101299
    I have been slowly converting my 2008 KTM 450 EXC to do some Adventure riding. I am still in the process of the conversion, however I thought that I would start a thread for those who may be interested. A few have questioned my thoughts on doing this, however I don’t have the coin to get a true Adv bike so this is the next best thing. I admit that it will require more regular maintenance than a true long hall Adv bike, however I have done quite a bit of testing and are very happy with the results to date. I am planning to do some long Adv rides a little later in the year as a few more dollars still needs to be spent to complete the Adv set-up. Having said that I don’t think an Adv set-up is ever complete so I think it may be on going.
    For initial testing I have tried various gearing for both torque/power and rideability in mind as well as optimum fuel comsumption. Before I rebuilt the engine with a Wossner piston and some porting and cylinder head work from my friends at RAMS Head service I was looking at a final drive ratio of around 15/50 however I decided to run with 15/48. By using this gearing the spread of ratio’s are superb and with the engine mods cruises comfortably at 120km/h acheiving 22 to 25km/ltr.
    Modifications to date;
    13ltr Acerbis Fuel Tank
    Bullet Proof Design Radiator Guards
    Giant Loop tank bag
    CPW Oil Cooler
    Enduro Engineering Bash Plate
    Bullet Proof Designs Swing Arm guard
    TM Design Rear chain guide
    270mm Artrax front brake rotor kit
    Teknik fork foot valve shim kit
    Teknik rear shock progressive rate spring
    15/48 Supersprocks gearing
    DID X-Ring Chain
    Michelin Ultra Heavy duty tubes
    Foam Rallye grips
    MSC Steering Dampener
    Motobatt 7A/hr Battery
    KTM Thermo Fan Kit with On/Off Switch
    Upgraded oil pump gears and shaft
    Revloc Clutch
    Front and rear “Tugger” lift straps
    Essential items still to get;
    Cush drive rear hub
    Comfortable seat (I hate the plank!!)
    Front Screen
    Rear fuel tank
    Giant Loop Bag on rear
    Pivot Pegs
    And lots MORE!!
    I will keep you posted……..
    The Left One! ;)
    #220175
    It looks great already lefty B) , you’re dead right though mate after every ride their seems to be something learnt and an addition to make !!
    Ill be watching this one with interest ;)
    You forgot Heated Grips and a Latte cup holder :P :laugh:
    Nice work Lefty, she is coming along nicely mate ;)
    #220187
    looks the goods lefty have fun
    #220188
    Thanks Gents ;)
    Motobatt Battery installation. (2008 EXC)
    I just thought that I would show a couple of pics for the installation of the new battery as it required a bit of a change. As the Motobatt is larger in capacity than the std battery from 5A/hr up to 7A/hr. If the battery cables were terminated on the top of the battery the seat wouln’t fit so I had to do a couple of mods so the terminals were now at the sides of the battery. At the same time I also ran a fused power supply to the front of the bike for futrure power requirements, this also allows me to plug directly in to the battery for charging.
    Take a look ;)
    Power supply at Bars
    Lefty ;)
    #220199
    Screen fitted
    more to come as it happens………
    #220805
    New seat from ACM (Australian Cumfy Motorcylce seats)
    See The difference…….. I hope that it is Cumfy!!
    Report to come later when tested.
    Lefty ;)
    #223803
    Matt
    Very nice seat
    44
    #220177
    Certainly looks the goods mate B)
    Keep me in the loop please Lefty,,,
    It looks very much like a Seat Concepts cover from the US (that get very good reviews too) :whistle:
    I am happy with my Airhawk at the moment, but an upgrade is on the cards in the future for sure
    #223807
    Looks good Lefty, wonder how the wider bit will go as I know some blokes find they rub the inside of their legs (Krusty was one that I think comes to mind, sometimes after 500 plus the Tenere does) :unsure: Has to be better than the Austrian railway sleeper :laugh: Did they supply it base and all?
    Steve is the agent for Concept seats as of two weeks ago Eags. Have you seen one in the flesh they are sex :) The foam and the covers are amazing he has got one for HIS Kato, the XR and the WR. I am going to get one for the Tenere and the XR :woohoo:
    Yep, I have seen them & sat on them (Seat Concepts)
    Deano has one as does MickP ;)
    GIve us more thoughts after testing please Lefty ;) ;) ;)i
    #223808
    I supplied the seat TB and they recovered it and shaped it. I told them my weight so they could match the correct foam density.
    #223810
    absolute sacrilege doing that to a KTM !!! and that seat, with your weight there would be no need for foam at all :laugh:
    #220179
    Currently got a 640 Adventure and have been toying with the idea of a 450 ADV bike for a while. Will keep an eye on your build. Looks great.
    #223978
    Well I have tested the seat on a 180km loop about 2weeks ago and I must give it a big two thumbs up. The seat was very comfortable and soft in the right places and also wide enough in the right area. so you don’t feel as though you are sitting in an Austrian Railway sleeper. :pinch:
    Here is the link to ACM if anyone is interested.
    Great Job ACM!
    http://www.acmseats.com.au/home
    Lefty B)
