This topic contains 22 replies, has 0 voices, and was last updated by Adrian Lee 14 years, 6 months ago.
August 8, 2011 at 3:00 pm #206371
Thanks Lefty
I wasn’t sure if it helped keep it cool or not as I have only noticed a few guys do it in there 525’s.
Does the needle height in the carby make a difference to the running temp, that’s what someone else said but I didn’t quite understand.August 8, 2011 at 3:16 pm #206622pete the wulf wrote:Does the needle height in the carby make a difference to the running temp, that’s what someone else said but I didn’t quite understand.Basically a leaner engine runs hotter then a rich engine.
August 8, 2011 at 3:34 pm #206623Can I just throw in there in winter richening of the jetting is desirable due to the colder/denser air. Your bike will be running leaner and will tend to boil easier.
I note from experience (Sunday) that my 300 puffed out a gasp of steam a good 10C under what it would in the warmer months. I have a trailtek vapor with temp sensor and was surprise it boiled at that temperature.August 10, 2011 at 1:10 am #206624axel wrote:Can I just throw in there in winter richening of the jetting is desirable due to the colder/denser air. Your bike will be running leaner and will tend to boil easier.
I note from experience (Sunday) that my 300 puffed out a gasp of steam a good 10C under what it would in the warmer months. I have a trailtek vapor with temp sensor and was surprise it boiled at that temperature.Just a note Axel.
The boiling temp of the coolant will be lower if your cap is on the way out and it bleeds off too early and/or the coolant hasn’t been changed for a while as it will go off. I would recommend a complete flush and change every 12mths. Coolant ratio 30% coolant 70% water. Using a good quality coolant 95% Glycol.Cheers
Lefty
August 10, 2011 at 3:08 am #206771Thanks Lefty good info. Will do.
September 8, 2011 at 5:18 pm #206776Check the radiator cap, have been told that they need replacing about every 3 yrs
HATTO
September 8, 2011 at 10:25 pm #206381Murph the surf wrote:Good one Lefty
Believe it or not that is what happened to the old Landrover/186’s thermostat. Rusted closed or part there of. :pinch:
Have heard of people fitting computer type cooling fans at a way lesser price of KTM’s price.
I believe the new 012 Katos are standard with a thermo fan.
Great idea, although it comes at a price, not financially.
But I think if you want radiator guards the one with the thermo fan is some what compramised.
Murphif you crash and burn a bit like me think you have to remove the radiater brace to fit a fan that is the compramise don t like that idear :unsure: think the brace on force guards is very usefull
September 8, 2011 at 10:31 pm #208425white rocket wrote:Murph the surf wrote:Good one Lefty
Or bite the bullet and buy a new kato, they come with thermo fans.
