KTM Engine/Gearbox Oil?
Home Forums KTM Bikes KTM Bikes KTM Engine/Gearbox Oil?
This topic contains 83 replies, has 0 voices, and was last updated by  Anonymous 16 years, 7 months ago.
Viewing 9 posts - 76 through 84 (of 84 total)
  • #145244
    Mr Blue wrote:
    Mr Rat, dissention is good, it’sd where good ideas are born, and I was probably exagerating about all year, depends on how many rides I do, but 10-12 medium rides on gearbox oil, would be rule of thumb, this year that would be about my total so far.
    And logic, who’s using logic, I just do stuff cause some bloke at the pub told me to…. :P I wish the Karma system was here I would pay for that one
    PS graphics came up great ta for that Bud. YOUR WELCOME MATE
    #145246
    Hey Guys
    My two cents worth here is that i change my gearbox after each ride on all my KTM 300 weather it 120 km’s ride or 500km’s, I just run the Motorex as KTM used and have had no problem at all with my gearboxes.
    I do sometimes change gear without clutch as well and there is no problems with at all.
    Dr D
    #145283
    Yeah but is that beacuse you keep hitting 4 foot deep water crossings at 50Km/h and falling in? :laugh: Sorry, had to say it!
    #121594
    Andrew
    I had an ’04 525 and ran Motorex from new and then switched to the Motul after about 6 months. Couldn’t notice any difference between the two and rode in all types of terrain and speeds. I did change the oil and filters every second ride regardless of klms travelled(as well as rear tyre:S ).
    Final thought…When you buy a performance machine, spend the extra bucks and buy a performance oil.:)
    #145144
    Paul Bayly
    Look I only offered an opinion after it was asked Beatle and why I had that opinion, use whatever you want I dont care but having just read your reply Beatle I thought it was a touch hard cause like I said you asked peoples opinions :blink:
    Good luck with whatever you use mate
    Please accept my public apology Trailboss. I should have put more smilies into my post as I certainly didn’t mean to offend anyone.
    As you say, I pays my money and takes my chances…..:)
    #145471
    ;) :laugh: :)
    Just for you Moto
    Was on the net and run across this moto:
    More Than You Ever Wanted to Know About Motor Oil
    by Ed Hackett
    (updated as of July 11th, 1999)
    Date: Fri, 9 Jul 99 21:22:04 -0700
    To: “H. Marc Lewis”
    My “oil” article at http://www.micapeak.com/info/oiled.html is the latest version. I haven’t had the time or desire to do any more with the article. It is as up to date as it’s going to get. Regarding the age of the data — you can now usually find current data on the oil company’s Web pages.
    Choosing the best motor oil is a topic that comes up frequently in discussions between motoheads, whether they are talking about motorcycles or cars. The following article is intended to help you make a choice based on more than the advertizing hype.
    Oil companies provide data on their oils most often refered to as “typical inspection data”. This is an average of the actual physical and a few common chemical properties of their oils. This information is available to the public through their distributors or by writing or calling the company directly. I have compiled a list of the most popular, premium oils so that a ready comparison can be made. If your favorite oil is not on the list get the data from the distributor and use what I have as a data base.
    This article is going to look at six of the most important properties of a motor oil readily availiable to the public: viscosity, viscosity index (VI), flash point, pour point, % sulfated ash, and % zinc.
    Viscosity is a measure of the “flowability” of an oil. More specifically, it is the property of an oil to develop and maintain a certain amount of sheering stress dependent on flow and then to offer continued resistance to flow. Thicker oils generally have a higher viscosity, and thinner oils a lower viscosity. This is the most important property for an engine. An oil with too low a viscosity can shear and loose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
    The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to “real” viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at various low temperatures depending on weight, and is therefore suitable for Winter use. 5W is tested at -25C, 10W at -20C, 15W at -15C, and 20W at -10C.
    The following chart shows the relationship of “real” viscosity to their S.A.E. assigned numbers. The relationship of gear oils to engine oils is also shown.
    _______________________________________________________________
    | SAE Gear Viscosity Number |
    | ________________________________________________________ |
    | |75W |80W |85W| 90 | 140 | |
    | |____|_____|___|______________|________________________| |
    | SAE Crank Case Viscosity Number |
    | |10| 20 | 30 | 40 | 50 | |
    | |__|_____|____|_____|______| |
    2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42
    viscosity cSt @ 100 degrees C
    Multi viscosity oils work like this: Polymers are added to a light base(5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
    Multi viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter base your decision on the lowest temperature you will encounter, in the summer, the highest temperature you expect. The polymers can shear and burn forming deposits that can cause ring sticking and other problems. 10W-40 and 5W-30 require a lot of polymers(synthetics excluded) to achieve that range. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best.
    Very few manufacturers recommend 10W-40 any more, and some threaten to void warranties if it is used. It was not included in this article for that reason. 20W-50 is the same 30 point spread, but because it starts with a heavier base it requires less viscosity index improvers (polymers) to do the job. AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Other multigrade synthetics may not use VI improvers either. The full literature available from the oil company should include this information. Follow your manufacturer’s recommendations as to which weights are appropriate for your vehicle.
    Viscosity Index is an empirical number indicating the rate of change in viscosity of an oil within a given temperature range. Higher numbers indicate a low change, lower numbers indicate a relatively large change. The higher the number the better. This is one major property of an oil that keeps your bearings happy. These numbers can only be compared within a viscosity range. It is not an indication of how well the oil resists thermal breakdown.
    Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendancy for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption. Flash point is in degrees F.
    Pour point is 5 degrees F above the point at which a chilled oil shows no movement at the surface for 5 seconds when inclined. This measurement is especially important for oils used in the winter. A borderline pumping temperature is given by some manufacturers. This is the temperature at which the oil will pump and maintain adequate oil pressure. This was not given by a lot of the manufacturers, but seems to be about 20 degrees F above the pour point. The lower the pour point the better. Pour point is in degrees F.
    % sulfated ash is how much solid material is left when the oil is reacted with sulfuric acid and burned. This is used to quantify the amount of metallic antiwear and detergent additives in the oil. Zinc dithiophosphate is a common detergent and antiwear additive that is reflected in this test.
    % zinc is the amount of zinc used as an extreme pressure, anti- wear additive. The zinc is only used when there is actual metal to metal contact in the engine. Hopefully the oil will do its job and this will rarely occur, but if it does, the zinc compounds react with the metal to prevent scuffing and wear. A level of .11% is enough to protect an automobile engine for the extended oil drain interval, under normal use. Those of you with high reving, air cooled motorcycles or turbo charged cars or bikes might want to look at the oils with the higher zinc content. More doesn’t give you better protection, it gives you longer protection if the rate of metal to metal contact is abnormally high.
    The Data: (Note: this data is mostly from 1991 and is for SG rated oils. Some of the data is current, and I am working on collecting the most recent data. I have found over the years that the “better” oils remain the “better” oils. It is still valid as a place to start in your own search. The formulation of oils is constantly being updated and subject to change by the manufacturer at any time. The best thing to do is collect data on the oils you are interested in directly from the oil company.)
    [An * after the oil name indicates current SH rated version.]
    Listed alphabetically. Empty cells indicate the data was not avaliable.
    Brand VI Flash Pour %
    ash %
    zinc
    20W-50
    AMSOIL* 151 507 -45
    AMSOIL Series 2000* 155 474 -47
    Castrol GTX* 122 440 -15 .85 .12
    Castrol Syntec Blend* 135 440 -17 .105
    Chevron Supreme* 140 428 -17 <1
    Exxon High Performance 119 419 -13 .70 .11
    Havoline Formula 3 125 465 -30 1.0
    Kendall GT-1 129 390 -25 1.0 .16
    Pennzoil GT Perf. 120 460 -10 .9
    Quaker State Perf.* 121 440 -20
    Quaker State Motorcycle 140 440 -25
    Red Line 150 503 -49
    Shell Fire and Ice* 126 450 -10 .9 .12
    Shell Truck Guard* 130 450 -15 1.0 .12
    Spectro Golden 4 174 440 -35 .15
    Spectro Golden M.G. 174 440 -35 .13
    Ultra Chem 190 455 -34
    Unocal 121 432 -11 .74 .12
    Valvoline All Climate 125 430 -10 1.0 .11
    Valvoline Turbo 140 440 -10 .99 .13
    Valvoline Race 140 425 -10 1.2 .20
    Valvoline DuraBlend 126 455 -17 <1.5 .125
    Valvoline Synthetic 146 465 -40 <1.5 .12
    15W-50
    Mobil 1 170 470 -55
    Mystic JT8 144 420 -20 1.7 .15
    Red Line 152 503 -49
    5W-50
    Castrol Syntec* 175 465 <-54 .102
    Chevron Supreme* 175 460 -38 1.45
    Quaker State Synquest* 175 460 -50
    Pennzoil Performax 176 -69
    5W-40
    Havoline 170 450 -40 1.4
    15W-40
    AMSOIL* 165 462 -49
    Castrol 134 415 -15 1.3 .14
    Chevron Delo 400* 134 424 -38 <1
    Exxon XD3 417 -11 .9 .14
    Exxon XD3 Extra 135 399 -11 .95 .13
    Kendall GT-1 135 410 -25 1.0 .16
    Mystic JT8 142 440 -20 1.7 .15
    Quaker State* 129 420 -25
    Quaker State HDX* 146 440 -30 .97
    Quaker State HDX Plus* 148 420 -25 1.37
    Red Line 149 495 -40
    Shell Rotella w/XLA* 146 414 -32 1.0 .12
    Valvoline All Fleet 140 -10 1.0 .15
    Valvoline DuraBlend 137 450 -17 <1.5 .125
    Valvoline Turbo 140 420 -10 .99 .13
    10W-30
    AMSOIL* 171 464 -54
    Castrol GTX* 143 415 -32 1.07 .12
    Castrol Syntec Blend* 138 415 -33 .105
    Castrol Syntec* 157 455 <-54 .102
    Chevron Supreme* 150 419 -27 <1
    Exxon Superflo Hi Perf 135 392 -22 .70 .11
    Exxon Superflo Supreme 133 400 -31 .85 .13
    Havoline Formula 3 139 430 -30 1.0
    Kendall GT-1 139 390 -25 1.0 .16
    Mobil 1 160 450 -65
    Pennzoil PLZ Turbo 140 410 -27 1.0
    Quaker State* 140 410 -30 .9
    Quaker State 4×4* 135 430 -35
    Red Line 139 475 -40
    Shell Fire and Ice* 155 410 -35 .9 .12
    Shell Rotella w/XLA* 155 405 -37 1.0 .12
    Shell Truck Guard* 155 405 -35 1.0 .12
    Spectro Golden M.G. 175 405 -40
    Unocal Super 153 428 -33 .92 .12
    Valvoline All Climate 130 410 -26 1.0 .11
    Valvoline Turbo 135 410 -26 .99 .13
    Valvoline Race 130 410 -26 1.2 .20
    Valvoline DuraBlend 142 440 -27 <1.5 .125
    Valvoline Synthetic 140 450 -40 <1.5 .12
    5W-30
    AMSOIL* 186 478 -67
    Castrol GTX* 160 410 -35 1.35 .12
    Chevron Supreme* 167 410 -38 <1
    Chevron Supreme Synt.* 169 468 -49
    Exxon Superflow HP 148 392 -22 .70 .11
    Havoline Formula 3 158 420 -40 1.0
    Mobil 1 165 445 -65
    Mystic JT8 161 390 -25 .95 .1
    Quaker State* 155 405 -35
    Quaker State Synquest* 168 450 -58
    Red Line 151 455 -49
    Shell Fire and Ice* 167 405 -35 .9 .12
    Unocal 151 414 -33 .81 .12
    Valvoline All Climate 135 405 -40 1.0 .11
    Valvoline Turbo 158 405 -40 .99 .13
    Valvoline DuraBlend 162 415 -38 <1.5 .125
    Valvoline Synthetic 160 435 -40 <1.5 .12
    Note: * indicates current SH rated oil
    All of the oils above meet current SG/CD ratings and all vehicle manufacture’s warranty requirements in the proper viscosity. All are “good enough”, but those with the better numbers are icing on the cake.
    The synthetics offer the only truly significant differences, due to their superior high temperature oxidation resistance, high film strength, very low tendancy to form deposits, stable viscosity base, and low temperature flow characteristics. Synthetics are superior lubricants compared to traditional petroleum oils. You will have to decide if their high cost is justifed in your application.
    The extended oil drain intervals given by the vehicle manufacturers(typically 7500 miles) and synthetic oil companies(up to 25,000 miles) are for what is called normal service. Normal service is defined as the engine at normal operating temperature, at highway speeds, and in a dust free environment. Stop and go, city driving, trips of less than 10 miles, or exterme heat or cold puts the oil change interval into the severe service category, which is 3000 miles for most vehicles. Synthetics can be run two to three times the mileage of petroleum oils with no problems. They do not react to combustion and combustion by-products to the extent that the dead dinosaur juice does. The longer drain intervals possible help take the bite out of the higher cost of the synthetics. If your car or bike is still under warranty you will have to stick to the recommended drain intervals. These are set for petroleum oils and the manufacturers make no official allowance for the use of synthetics. Some oil companies, AMSOIL being an example, offer their own engine warranties. If the oils are used in compliance with the company’s recommendations (including extended drain intervals) and a problem is caused by the engine oil, the company will pay for the repairs. Check with the company for specifics of any warranties offered.
    Oil additives should not be used. The oil companies have gone to great lengths to develop an additive package that meets the vehicle’s requirements. Some of these additives are synergistic, that is the effect of two additives together is greater than the effect of each acting separately. If you add anything to the oil you may upset this balance and prevent the oil from performing to specification.
    The numbers above are not, by any means, all there is to determining what makes a top quality oil. The exact base stock used, the type, quality, and quantity of additives used are very important. The given data combined with the manufacturer’s claims, your personal experience, and the reputation of the oil among others who use it should help you make an informed choice.
    #145576
    I cut and pasted this earlier in thread :P
    #121595
    AUTO TRANS OIL WORKS GREAT MOTOREX MAKE A DEXTRON 3 IT IS THE BEST I HAVE FOUND ON CLUTCHS AND LO DRAG WHICH = A LITTLE RISE IN HP
