This topic contains 12 replies, has 0 voices, and was last updated by Greg 12 years, 9 months ago.
June 5, 2013 at 9:32 am #102843
Does any one have a KTM lower Triple Clamp to Suit KTM LC4 640 05 mod
I just pulled my fork apart to re seal and found one of the lower sides of the Triple Clamp to be a tad looser than they should be. Found a crack most of the way through. :ohmy:
Diameter is 60mm
Centre Distance 190mm2 1/2 week till the Next GPS Ride PLEASE HELP
June 5, 2013 at 10:49 am #243110Thats no good Gav,
Hopefully you can find one.June 5, 2013 at 10:55 am #243119Definately wont be on this weekends ride now
June 5, 2013 at 11:02 am #243111Damn :pinch:
Good luck with that one Gav ,,,
I think Lefty recently replaced a top triple on his 640 with the new Damper install :whistle:
June 5, 2013 at 11:48 am #243121EAGLE`02 wrote:Damn :pinch:Good luck with that one Gav ,,,
He is after a lower Eags :whistle: :laugh: :laugh:
June 5, 2013 at 12:08 pm #243112I know,,,
I was being sarcastic or sympathetic, or empathetic or something :laugh:Good Luck Gav
June 5, 2013 at 12:50 pm #243113gavb wrote:Does any one have a KTM lower Triple Clamp to Suit KTM LC4 640 05 modI just pulled my fork apart to re seal and found one of the lower sides of the Triple Clamp to be a tad looser than they should be. Found a crack most of the way through. :ohmy:
Diameter is 60mm
Gav I’ve got one but it attached to a DR650
I suppose you have checked, a new one is about $300 if available in AU
Coffs JDK M/C wreckers have a complete set off an 04 LC$ for $300, but they may only be for 57mm forks. The adventures look to have larger forks :unsure:
Mick
June 5, 2013 at 10:16 pm #243114I’d probably put it back together, put a SS hose clamp around it until the new clamp arrived.
June 6, 2013 at 2:54 am #243115Ok …
There are CNC machined Billet Triple Clamps 22mm Offset. Reasonable Price.
Original offset is 19mm I think.Question ? What difference will this make to performance ?
3mm bigger mmmmmm :laugh: :laugh: :huh:
June 6, 2013 at 3:11 am #243133Off set will alter how it steers Gav, steeper off set steers better but more twitchy at high speed and vice versa
June 6, 2013 at 10:53 am #243134Apparently the angle on these is the same. The offset is how far forward the fork centreline is from the pivot centre line. What is 3mm among friends…..
June 6, 2013 at 12:17 pm #243146gavb wrote:Apparently the angle on these is the same. The offset is how far forward the fork centreline is from the pivot centre line. What is 3mm among friends…..Gav it makes a biggg difference – you can notice quite a difference even when you move the forks up/down in the triple grips 10mm which changes the rake of the forks.
Pushing them down slows the steering (more stable at higher speed but slower to turn at slow speeds)
So if you have an extra 3mm it will have a much more noticeable affect than just pushing your forks down and make it slower to turn in the slower tighter stuff.
Mickp
June 6, 2013 at 8:15 pm #243150mickp wrote:gavb wrote:Apparently the angle on these is the same. The offset is how far forward the fork centreline is from the pivot centre line. What is 3mm among friends…..Gav it makes a biggg difference – you can notice quite a difference even when you move the forks up/down in the triple grips 10mm which changes the rake of the forks.
Mickp
Thanks for the detail Mick I didn’t have time to type it all buts it’s what I meant
