KTM450 EXC-R 2008
Home Forums For Sale For Sale KTM450 EXC-R 2008
This topic contains 5 replies, has 0 voices, and was last updated by  Geoff Forshaw 12 years, 11 months ago.
  • #102223
    FOR SALE
    KTM450EXC-R 2008 Model ($5500)
    Goodies list
    NSW Rego until end of September 2013
    270mm fully floating oversize front disc rotor with near new sintered pads (standard disc and bracket included)
    Teknik fork T-Valves in front forks
    MSC Steering Damper
    Bark Busters
    Enduro Engineering bar risers
    Motobatt 7A/Hr AGM battery
    KTM Power Parts Seat
    Genuine KTM Radiator Fan kit
    Genuine KTM Plastic frame guards
    Teknik T3 Progressive rate rear spring + STD 72-250 Linear rear spring
    Revloc Clutch , Made in the USA (Similar to Rekluse)
    Wossner piston with RAMS Mildly ported cylinder head
    Dirt Tricks Cam chain Tensioner
    Upgraded Oil Pump Drive Gears
    Upgraded Oil Pump Drive Shaft
    Bullet Proof Design (USA Made) CNC 6061 Aluminium Radiator guards
    Bullet Proof Design (USA Made) CNC 6061 Aluminium Swing Arm Protector
    Bullet Proof Design (USA Made) CNC 6061 Aluminium Rear Disc Protector- Shark Fin
    Gearing 14/52 Supersprox rear sprocket
    Barrett Exhaust End Cap
    New Spare Levers; 1 x Clutch + 1 x Brake
    New Spare Gear lever
    Spare Genuine Air Filter + 2 Spare new Oil filters
    New Front Guard + New EGO Bark Buster covers
    Lefty B)
    #234786
    Bump ;)
    #234787
    Adrian Lee
    How much would you want without all the adventure gear?
    #234963
    Base bike as follows;
    $5500
    KTM Power parts seat
    Std Tank and Radiator shrouds
    MSC Steering Damper
    Bark Busters
    12v power supply at handle bars direct from battery (for easy charging)
    Enduro Engineering Aluminium Bash plate + Std plastic unit
    T.M Designworks Chain Guide
    Talon 14/52 Supersprox rear sprocket
    New Front Guard
    Foam Rally Grips
    New Clutch Cover Gasket
    New Water pump cover gasket
    2 x Spare oil filters (New)
    Tyres Michelin T63 Front Approx 25% Worn; Rear Approx 50% Worn
    Lefty B)
    #234966
    Bumpity Bump ;)
    #236089
    SOLD! ;)
