KX60-won’t find better
Home Forums For Sale For Sale KX60-won’t find better
This topic contains 0 replies, has 0 voices, and was last updated by  Bruce Curtis 14 years, 6 months ago.
Viewing 1 post (of 1 total)
  • #100451
    Ok Brentons almost immaculate 1998 (same from 92-02) KX60 is up for grabs
    Is a very clean Kawasaki KX60 setup for mostly trial and general use by a younger person
    modifications include
    FMF Silencer that makes it infinitely quieter yet gives better torque
    Easy-pull clutch
    Porting work on the transfer and inlet ports, has had extra base ports cut in to enhance bottom end and mid-range.
    3mm Spacer in exhaust to give better torque
    Perfectly Jetted, pristine carb with almost unmarked slide
    Advanced ignition
    Shaved seat with gripper cover so it removed the stupd lump they have at the rear and gives it a cleaner look and better to move around on.
    Easy pull throttle
    Aftermaket bars specifically for KX60 in nice shiny alloy easy sweep and rise
    Forged wide pegs for better grip
    longer steel gearlever as the standard one is rediculously short, even a kid with size 1 feet couldn’t get under it.
    Grab strap
    probably more just can’t remember tried to make it the perfect little bloke(ette)s ride
    bad stuff
    Crack radiator plastic guard, easily fixed just havent got around to it
    Could do with rings in next 10 hours
    Last week he lost the rubber gasket of the filler lid, but I will get another
    Due for chain and sprockets about same time as rings
    Ummm that’s it
    Spares
    Got an engine rebuild worth of gaskets maybe three engine rebuilds enough
    levers/bars/pegs etc
    just yell at me if interested
    Bike located in Northern NSW, can help with transport like take it to depots or meet somewhere reasonable if needed etc
    $1000 o.n.o
