Leaking ktm 450 R/H fork
This topic contains 3 replies, has 0 voices, and was last updated by  murph the surf 13 years ago.
  • #102433
    Hi. Recently “inherited” my sons ’04 KTM 450 EXC. The R/H fork is ALWAYS leaking. This is despite numerous (3 or 4 now) seal changes, bush changes – all done by local bike shop, using OEM parts. It seems that if there is a tiny bit of air in the forks, the seal leaks. Purge the air thru the bleeder and problem goes away. Just sitting in the shed, there is usually a 50mm pool of oil on the ground, oil on the rim/tyre and down the shaft. What is the best fix and how many dollars should I be looking at?
    I have seen a pair of forks advertised on ebay from an ’09 450 EXC. Will these fit?
    Any advise from OB experts would be appreciated.
    Cheers Budge :(
    #237265
    Nick Dole
    Hi Budge,
    You probably have a decent scratch or vertical score in the tube. For what it’s worth to re chrome the tubes of get the 09 forks, they slip straight in. Internals are way better than the 04.
    #237284
    Hey Budge
    My 07 525 fork seal became a joke
    Was changing it every 2 rides or so
    If you look in the “Tech Help” section and go back to page 6 you will see a thread called “Furked Fork” Lucky I am a fitter by trade so the fix didn’t cost anything
    The devcon held and I got many more thousands of kms out of the old girl before selling her
    Hope this is not the issue with your bike
    Worth a look though
    P.S. With the bore flogged out where the bush sits it enables the inner leg to move around too much in the outer tube, thus causing the seal to leak. Best of luck.
    #237266
    Thanks guys. Appreciate your advise and will keep you posted on the remedy. Cheers Budge
