Loose sprocket bolts, check your nuts
Home Forums Rocks Motorcycles Honda Forum Rocks Motorcycles Honda Forum Loose sprocket bolts, check your nuts
This topic contains 16 replies, has 0 voices, and was last updated by  murph the surf 12 years, 8 months ago.
  • #245362
    Yes I know I used plenty of the loctite but most of that was squeezed out when the bolts where done up,so it does in fact have only a very thin layer of the blue stuff. I will no doubt be keeping an extra vigilant eye on it for a while. ;) The Devcon should handle the torque as Long as the sprocket doesnt move,the rear of the flanges were not flogged out they where still round,so as long as the nuts stay tight all should be good. Hopefully :unsure:
    Hope that repair hangs in there Ollie. I’ve used devcon in the past to repair engine cases but never tried it on something that will take on a bit of torque.
    As for sprocket bolts I religiously go over mine with a spanner ever time I lube my chain. It is overkill but a good habit I have fallen into (I don’t have many good habits) and I’ve never had a failure.
    #245380
    Nick Dole
    Ollie, you are more adventurous than I am.
    I hope you have a case saver on it. Bring the engine down to me stripped or not when you hole the engine covers after derailing the chain, i’ll weld them up so the oil stops falling out.
    “good luck” and find a good used hub before you do enough hours to see if it works.
    #245421
    We will see???????????????????????????????
    I have no long time faith, but?
    I do belaive in what he has done!!!
    Time will tell??
    One in ten????????????????
    Rusta??
    UB40 !
    Some is good!!!!!!!!!!!!!?
    >>>>>>>>>>>>>m,lmpohyif96532w53trdf89i
    Richard W
    10 out 10 for effort Ollie. Time for bed I think Murf.
    #245443
    I am supposed to be doing some T-Day, Training Bullshit, day.
    Most the boys like them, cause its a bludge day!!!!
    I hate them with a passion :sick: :sick: :pinch: :angry:
    Had a sniff of a bit of NE swell for tomorrow. :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
    Gotta love that!!!!!!!! B) B)
    Far better than the said “T-Day”
    Murph the surf!!!!??????????
