Home › Forums › Rocks Motorcycles Honda Forum › Rocks Motorcycles Honda Forum › mods for cfr 250x
This topic contains 15 replies, has 0 voices, and was last updated by Paul 16 years, 5 months ago.
September 8, 2009 at 3:48 am #97120
does any one have any mods they have done or recommend to be done to the 08 crf
thinking of putting a 13 tooth front sprocket for a bit more bite but am thinking of doing some more serious engine mods, but this honda bit is full of xr dinosaur info lol
September 8, 2009 at 3:52 am #151482I know some mods,but because of the Dinosaur XR statement I’m not telling you. :laugh:
September 8, 2009 at 4:11 am #151485But you could start looking into a JD jetting kit.
Desnorkle the airbox.
A nice pipe and a hotcam maybe worth a look to if you want to get her really cracking.September 8, 2009 at 4:12 am #151488and there is talk of stainless valves too.
September 8, 2009 at 4:15 am #151483Hi Scotty,
you’ll probably just have to trawl the google pages
http://www.rickramsey.net/CRF250Xmymods.htm
“Pink wire” maybe, and the foot break lever mod makes sense.
270 big bore kit? :silly: :woohoo:
there is a lot of talk on thumper talk.
September 8, 2009 at 4:17 am #151489
AnonymousThe valves on some were an issue so it would worth keeping your eye on them and regularly checking for problems/tolerance issues (I refrained from adding to check for the valve in your exaust pipe :laugh:).
Hot cams seem the go with the CRF’s and of both people I know that have fitted them say they were a great mod with noticable power increases.
September 8, 2009 at 4:24 am #151490Hold the throttle on longer, get on the brake later and get on throttle earlier :laugh:
Seriously, get your suspension done by a professional first, its the single biggest and best mod
After that worry about pipes, big bore kits, bling etc
September 8, 2009 at 4:31 am #151493
AnonymousSince you stated you wanted more bite I mentioned the apparent effectiveness of the hotcam, but I agree with TB, if you want to actually ride faster getting your suspension setup would be money well spent
Followed by a steering damper too (although I still don’t run one).September 8, 2009 at 10:02 am #151497i was told by greg ball, a very reputable engineer with a lot of experience with crfs, not to put stainless valves in the 250 as it robs a noticeable amount of power from the motor. just putting an after market pipe with the right jetting and a couple of teeth up on the rear makes a really big difference.
September 8, 2009 at 11:33 am #151484Hey scotty . I have an 08 250x aswell. I’ve already done the air box mod and within the week should have a new pipe on. Will let you know how it goes… But there’s still plenty of mods to do. Just google crf mods on the net. Then start saving your coins!
September 10, 2009 at 3:50 am #151564thanks guys i seriously need to save some money now i think my eyes are bigger than my wallet (:
September 10, 2009 at 3:51 am #151921I was only joking about the xr jibe i started on the xr 250 and couldnt kill it
September 10, 2009 at 3:53 am #151923who is local ( gosford area) i could taketbike to to get my suspension set up
and a rough idea on costs?September 10, 2009 at 4:00 am #151922scotty h wrote:
Quote:thanks guys i seriously need to save some money now i think my eyes are bigger than my wallet (:have you looked into the stuff you can do yourself? only cost you some time.
may be look into a teeth or two bigger on the rear for now, until you get the suspension sorted. give you that bit more punch out of corners etc.
October 9, 2009 at 8:42 am #151565scotty h, I’ve put a pro circuit ex-haust tip and header pipe on my 250. Have only had one ride with it so far , The difference I found was in the mid range ( a positive difference for sure). It rode ok with out any mods to the jetting, So when I get around to it I’ll have a little muck around with that aswell, Maybe even a dyno tune!!!
