Most Common Flat Tyres – front or rear
Home Forums General Bike Talk Most Common Flat Tyres – front or rear
This topic contains 9 replies, has 0 voices, and was last updated by  Greg 17 years, 6 months ago.
  • #95070
    Not that I actually do much riding, but I have never had a flat tyre from puncture, whilst trail riding.
    Which tyre normally gets the most punctures? Is there any trend as to which tyre usually cops it?
    Nigel
    #107680
    Toby
    Front generally because it is the first to smash that big bundy. Spent the week end riding some new BMW G450Xs and we got two flat fronts within ten minutes of each other. Some poeple carry a 19″ because you can use it in the rear and strech it into the front (but it is a bitch to do)> I just carry a front because you can just ziptie on the rear if you have to.
    #107681
    Fronts for me, pinched tubes (high country ride 2006 had 3 in one day)even ultra heavy duty tubes can be pinched when you drop pressures searching for traction. Also damaged rims, dented front rims when using tubes and low pressure was a problem I solved when I switched to mousses.
    Think I have only had two rear flats that I can remember in my adult life, once because of hitting a hole and broke two spokes, I stopped and saw the broken spokes, turned for home and soon had a flat from the spokes not be cable tied and piecing the tube. The other was from to low a pressure at Louee because of the rocks and 14psi
    Last time I was at Louee, Tom had a huge sign posted in his shed saying something like “ALL TYRES TO BE AT 18 PSI”. I guess he got fed up with putting in new tubes, for which he normally doesn’t charge for labour, just the tube itself.
    #107686
    Brett
    Rear for me nail/wire on a ride to Orange and back with TB, tried patching 3 or 4 times before TB got the shits with my patience and threw the tube into a tree near Hill end so I put the a 21″ front in the rear which got us home approx 400ish kms pull it out and kept it for a spare looks good.
    #107687
    Chicken I want to do that Orange ride again soon, thats an extreme ride for two days, 500 odd kms a day how about it
    #107682
    Hey Fossil hows about a report on your impressions of the BMW 450?
    #107700
    That could go in the ride reports, would love to see your thoughts on such a big move into the market by BMW Fossil
    shane
    One rear on the Vor in 6 years…I should get out more???
    #107684
    I only get rear flats here guys as the KTM front wheel hardly touches the ground, I suppose it would be a Honda thing to get front flats. Seriously its more an inflation issue or lack of it that causes dramas, front or rear !!!
