Motion Pro- T6 Combo lever
Home Forums Product Reviews Product Reviews Motion Pro- T6 Combo lever
This topic contains 1 reply, has 0 voices, and was last updated by  Stuart 15 years, 10 months ago.
  • #98504
    For years I have been trying to reduce the weight of my bum bag Seen here
    I wasn’t happy with my rear wheel spanner as it wasn’t long enough I felt to get a tight axle nut undone trail side. When I first saw the Motion Pro T6 combo spanners I thought yeah whatever. Then when I picked it up and realised it weighed only 90grams and had a tyre lever at the other end I was stoked, a third lever trail side makes the job so easier. My only real concern was would it be strong enough, the tyre lever end. Its made from lightweight forged aluminum and has a hard anodised finish. The lever appears strong enough that even the monkeys in the tyre changing video at the Kenda couldnt break it :P
    The Motion Pro- T6 Combo lever comes in a heap of different sizes
    12mm or 13mm for you rim lock nuts or you can get one with your rear axle nut size either 22mm, 24mm, 27mm or 32mm.
    I paid my hard earned and reckon its a good thing, recommended retail is $55.00 but if you ring Mal or Scott at Sutto’s they will hook you up for $45.00 which is a ripper saving :)
    Stuart
    badbowie & I have been carrying these for over 12 months now, previously carried 2 Ballards specials & a no name $10 lever + a hybrid wheel spanner.
    Weight saving by ditching the steel for aluminium was near on 500g
    Noticed less damage to tyres as the pressure is spread over a wider area than the previous lever & the bead doesn’t tear
