Home › Forums › Product Reviews › Product Reviews › MSR MXT Boots, a month down the track
This topic contains 6 replies, has 0 voices, and was last updated by Bruce Curtis 16 years, 9 months ago.
June 23, 2009 at 2:40 am #96662
It’s been a month now since acquiring my new MSR (Mountain safety research) MXT boots, been on three rides with them and spent the better part of 20 hours using them so feeling reasonably confident to give an appraisal.
General description- a combination leather /plastic boot aimed at the middle ground buyer who is looking for high end comfort and wear, very very similar to some of the tech series boots in appearances, non-hinged and non bootied, with fairly agressive tread pattern
Comfort- Excellent, Easy to fit, the old ankle trap is almost non-existant, and offers top amount of padding in both sole and calf area. I would get one size above normal boot fitment on most off-road boots anyway so same goes here, dosen’t let moisture in unless in extreme water crossings.
Buckles and secure fitment- Hinged evolution system of what has been around since Moses rode his XR500 in the original thumpernats, a bit fiddly at times and offers not only the ratchet on the male portion but two fulcrum points on the alumium buckle itself, self centreing buckles with large thumb clasp area, very top of boot has very agressive velcro for seling elements out, velcro can hinder buckle at times as it tends to grab before top portion is firm, but easily overcome by resequencing your approach.
Feel and gearchange and braking- maybe this is partly the Pivot pogz fitted to my bike, but once i repossitioned my gearlever up one notch (thicker than the O’neals I previously wore) gearshifts are positive and neutral is easier to find, braking is initially a bit “heavier, but less pressure was the order of the day, as these boots required less input to move the lever, maybe the sole is slightly different shape to old ones, kickstarting doesn’t slip off lever even when lever is coated in yellow clay, an old bugbear of mine, used to put rubber hosing on kickstart levers to combat this in years gone past.
Feel is good, ankle movement is reasonable, then restricted where you want it to be by way of plastic placs meeting on the outside of the boot, should pose little risk of broken ankles, shin protection is tops, very heavy plastic plate has copped afew blows so far, not even transferred to other than a foot deflection, no marks on lower legs, did find fitting my kneeguards a bit more of a chore as the velcro doesn’t encourage kneeguards.
Walking is typical Off-road boot, but with better ankle movement is more natural and going up and down inclines good, don’t slip too much in mud or clay either.Value for money- Tops at around the three hundred- four hundred dollar zone for mid-range boots mark one should consider these boots as I have seen much more expensive ones with less comfort and worse buckle systems, there was a rumour they are rebadged Tech 4s, but I tend to believe they aren’t as Tech 4s aren’t as comfy, and these are the most comfortable off-road boots I’ve ever owned, moreso than my old Scotts, Axos, Alpinesstars or the stylish bright red Vendraminis with Booties.
Would I buy another pair? talk to me in 18 months cause i demand a good life expetency out of all of my boots, and if they wear as well as they wear
I’ll be buying another set in 5 years.Bruce Cee
June 23, 2009 at 3:31 am #140729Sounds the goods so far MrBlue!!!
Keep us in the know how they go over time mateJune 23, 2009 at 3:34 am #140730Good thorough report there Bruce. Any Ideas where they are available?
June 23, 2009 at 3:34 am #140733Just some extra detail Blue if you dont mind me adding to your thread
And of course the sales pitch
MSR MXT Boots
. Improved overall fit with a large calf circumference
. The overall design boasts many of the same amenities as boots costing hundreds
more
. A genuine leather shell offers support and durability while making break-in fast and
easy
. Ergonomically designed external plastics at every key point protect from wear and
impact
. Aluminum Cam locking buckles are simple to use and adjust to a wide selection of
tension positions quick and easy
. The interior features an embossed biofoam calf area, a smooth padded finish and a
padded inner sole pad
. Suede at the exterior calf resist heat from pipes and wear while avoiding damage to
your bikes finish
. And at the bottom of it all is a welt stitched durable sole with a steel toe plate
. Each component designed with function, protection and durability in mind.TB
June 23, 2009 at 3:51 am #140735I know my local Bloke would get them, but i got mine from a young Bloke who had worn them once around the driveway before his job fell through an his brand new quad was repossessed, did a bit of research before I bought them for next to nothing, but after having them would quite happily pay retail for them.
Mick I know partsmonster stocks them.
Bruce C
June 23, 2009 at 3:53 am #140734micknmeld wrote:
Quote:Good thorough report there Bruce. Any Ideas where they are available?http://www.partsmonster.com.au/rider-essentials-boots-c-86_103.html
June 23, 2009 at 4:18 am #140731Good Value for $280;)
