Mudgee soil
Home Forums General Bike Talk Mudgee soil
This topic contains 55 replies, has 0 voices, and was last updated by  Eric Smith 16 years, 6 months ago.
Viewing 15 posts - 1 through 15 (of 56 total)
  • #97178
    Ok 10 days til the big event,, and I dont know what to wear,, Should I go for a soft soil, rear tyre or a medium soil, a good in the mud or just chuck on a good condition cheap and nasty like my fortune?????
    Thanks
    All the reports I hear are that it’s very rocky and a tyre chewer so an older tyre if you have one knocking around may be the go. I’ll have my new steering damper by then :woohoo:
    #152830
    Glenn
    Which brand did you decide on?
    #152832
    fortune..cheap and nasty should do the trick!!!
    #152834
    Wouldnt run a fortune up there myself Boony. I have only ever seen two fortunes run now and both have had a hole torn in the side wall by a rock, and my god Louee has some rocks. They seem to be a cheap tyre with a cheap case? Just what I have seen, Champo tore a hole in the side wall of his
    Champo did his with a stick I think, it wasn’t even a rock if I remember correctly.
    #152837
    would increasing the pressure help???????say 18psi
    #152840
    I’d recommend 40+
    Bar not psi :laugh:
    #152841
    Higher pressure might help against getting a flat, but a fortune on rocks running 18psi :ohmy: The ribs will be the least of your worries!
    #152843
    Mmmmmmmm maybe the carlsbad???
    #152844
    18 psi is what they recommend at Louee (Louee that is) Something known with decent case Boony
    TheBoss
    This is in tech help you two, on topic, those of topic posts have been deleted
    #152845
    smiley-sick029.gifCarlsbad…
    No.
    Try a Dunlop 756 mate, good all rounder about the same price. Or if you can get one, a Maxxis IT.
    #152857
    TheBoss
    Tech help Rat read the rules
    #152863
    I have a Dunlop 952 on the back (756 on the front) and it seems fine with all the rocky stuff. I normally run 14 psi but as TB said 18 psi would be better at Louee. There are some rocky parts right up the back.
    I have a Carsbad on the back of the Husky and it’s going ok. Has got me up most hills and even gripped enough to flip on one hill. What issues have you had with them ECKS?
