MX80 tank
Home Forums Tech Help Tech Help MX80 tank
This topic contains 3 replies, has 0 voices, and was last updated by  Matt 13 years, 11 months ago.
  • #101253
    Peter Reid
    G’day
    I’ve got an mx80 with a rusty tank (inside only) does any one know what I can use to get rid of it? It’s only surface rust but I reckon it will only get worse. The rest of the tank and bike, for that matter is in great nic.
    If anyone can help, that would be great .
    Thanks
    Hoss
    #219557
    i reckon there would be a few boffins..or boof heads on this site that would know what to do Hoss…i’m a mechanical spastic…but…worst case there is one fleabay at the moment with good lining on it’s guts..apparently :huh:
    heres the link
    http://www.ebay.com.au/itm/Yamaha-MX80-petrol-gas-fuel-TANK-/330712438393?pt=AU_Motorcycle_Parts_Accessories&hash=item4cffff5679
    well..i think its a link. :blink:
    Good luck and cu on the trails soon :)
    Matt
    Hi on another forum im hearing white vinegar if its surface rust.
    or this stuff http://www.ftrs.com.au/redkote/red_kote_distributors.php
    or http://www.kbs-coatings.com.au/kbs-motorcycle-tank-sealer-kit
    or Put in some phosphoric acid and turn the tank around several times until its all coated, this will disolve all the crud and rust deposits. Leave it in there for while it won’t hurt. Then wash it all out (comes out like foam) with water and try to dry the tank quickly with a heat gun and compressed air. You can then flush with some Methalated Spirits as this causes the water to run out and will disperse it. Should be clean as a whistle after this.
    All tis is copied from another forum i look at so if it melts the MX80 to the ground dont blame me hahahahaha…
    44
    #219558
    Richard W
    When its fixed try to keep the tank full at night.
