NEW 350 EXC-F
Home Forums KTM Bikes KTM Bikes NEW 350 EXC-F
This topic contains 32 replies, has 0 voices, and was last updated by  Damien Bonora 12 years, 10 months ago.
Viewing 15 posts - 1 through 15 (of 34 total)
  • #102010
    Hi all,
    I am picking up a 2013 350 EXC on Saturday morning and have the rest of the weekend to prep it for its maiden voyage the following weekend. ;)
    I have not had a Kato before so I am after any tips that you might have in setting up the bike, clickers, what will need more grease etc, how far to run the forks thru the clamps, and any little tricks that are beneficial to do on a new Kato.
    Any help would be appreciated.
    BRING ON SATURDAY!!!!
    #231633
    setting up clickers and fork height is almost as individual as we are.
    as for extra grease i’ve not read/heard of any areas. maybe just put some fresh quality grease in all the spots you can find a grease nipple.
    the only thing i can think of is if you are 20-30kg or more either side of the usual 75-85kg range the suspension is set up for, you may have to visit a suspension shop at some stage.
    apart from that, fresh PULP , run it in and ENJOY :woohoo: ;)
    #231648
    Don’t think you’ll find any grease nipples on a Kato
    But like XY says you may need heavier (or lighter) springs front and back
    I’m up around the 100kg geared up and have put heavier springs in my last three Kato’s
    Trailrider,
    Put some grease in the wheel bearings and seals ;)
    At the very least between the dust seals and bearings, mine had none :(
    Other than that change your fuel filter from time to time and service as per the manual (I do mine at about 20 hours) and you’ll have no problems.
    I haven’t bothered with the 105 hour crank bearing change etc as I don’t race and the motor hardly ever gets past half revs :blush:
    Have fun on it :woohoo:
    #231668
    Hi Adam,
    Thanks for the heads up on the wheel bearings / seals – gotta pull the wheels off any to put ultra tubes in.
    i’ve already given the hard parts book , and my bank acc, a floggin’ so i’m gonna have a heap of fun before i even get on it!!
    Will post some pics next week once she is ready to go ;)
    #231679
    Steve Wyeth
    Shock sag is much mpre critical on a KTM than other bikes as it doesn’t use a rising rate linkage, it has PDS.
    You won’t get the right sag numbers unless you have the correct springs for your weight. Like Murph I have changed all 3 of my KTM/Berg springs as I’m heavier too. If you’re much more than 80Kg without gear you’ll likely need to this and it would be my first mod.
    If you can’t afford to do springs both ends after shelling out for a new bike do the shock first and then the forks when you can.
    I always set clickers to ‘comfort’ and tweak from there. This depends on your weight though, if you are too heavy for the stock springs you may need to set the clickers to ‘sport’ to compensate.
    Have fun on it, I still need to hit Adam up for a go on his. I’ve only ridden one for about 2 minutes helping someone out of strife.
    #231682
    Thanks for your thoughts Moto,
    Dealer checked the sag when i was there last weekend and said it was ok – just. I probably prefer it a little softer and lower as I am just a simple trail rider :) I am 85 Kgs, sometimes 😆 I have heard previously that it needs to be spot on with the PDS, so I guess ill take for a run and see how it goes……
    #231635
    Trailrider,
    I checked my hours and km’s when I got home this evening. I’ve clocked up 5150 km and 170 hours so far.
    You shouldn’t have any dramas other than the usual consumerables if you treat her right, (a bit like your wife :P )
    #231729
    Thanks Adam, not sure about the wife bit, I hope the Kato will be alot less moody :ohmy:
    #231730
    Hi Adam,
    Do you run a map switch on yours and if so which one?
    #231842
    Trailraider wrote:
    Hi Adam,
    If you ride as per your site name then apart from correct springs (especially rear), bash plate and barkbusters you won’t need anything else.
    Both Krusty and I run stock exhaust and ignition. It’s handy to be quiet when you need to :whistle:
    and if you do general trail riding / singletrail stuff you should be fine they have enough power for us ;)
    Sam took mine to the Stockton dunes with a few blokes and said he had no problems riding there, but would have struggled on his 250.
    When you open them up they get going, I’m not sure what motor differences there are between the 12 and 13 model :huh:
    Give it a try standard and if you feel your lacking have a play around with settings, mappings etc.
    I agree with Moto, and I set my clickers to comfort (your out to enjoy yourself afterall) and have only slowed the rear rebound slightly
    PS I’ll be riding next Saturday with Krusty and Action (will post this up soon) in Ourimbah again if your in need of somewhere to ride.
    Enjoy your weekend :woohoo:
    #231844
    Thanks Adam, I’m hearing ya mate!!
    No plans to change exhaust, i just thought it might be nice to be able to turn it down a wick when you get on a slippery section on a wet day? but your right, i’ll try it standard first and see how we go.
    Just gettin a little excited :)
    #231845
    Steve Wyeth
    Typically the map switches are more noticeable from the middle of the RPM range and up and even then it’s not a massive difference, just with the edge taken off a little.
    If it’s slippery going to the point where you are struggling you shouldn’t be up in the revs anyway and therefore the map switch in that scenario will do practically nothing.
    I use it to add extra snap when riding the faster stuff. In conjunction with the fuel EFI tuner I have ‘angried’ my bike up, I use the map switch switch to tame it down or when I’m tired. Mostly it’s left in aggressive though.
    You’d be better off putting the money towards a new tyre if running a totally stock bike B)
    #231847
    Like Moto said
    Money towards new tyres
    My bike came with crappy rubber
    I have a three stage mapping switch mounted on the bars of my 500 and only rarely change it if I’m getting tired towards the end of a hard day
    Enjoy
    Hey Trailrider :)
    I rode one the other day at nundle…had to :ohmy: as one of the peanuts i was riding with took off with my crf 450 :angry:
    Awesome bike in the tight stuff but my muscular body was too much for the suspension :dry:
    Gear the suspension to your weight and let it rip !! :woohoo:
    Have fun B)
