Home › Forums › General Bike Talk › New toy
This topic contains 17 replies, has 0 voices, and was last updated by murph the surf 14 years, 5 months ago.
October 1, 2011 at 4:22 pm #100560
Just finished cleaning my new toy
A little more time consuming than the 525 as there are more folds and overlaps (much like mysef. :laugh: ) in the plastics
Had a great ride yesterday with Tim and young Damo
Things that need to be done are:-
Bar raisers as I am just a little too uncomfortable with the standing position
Maybe a couple of teeth smaller back sprocket as I seem to be changing gear alot more than the 525
The rear tyre must go it doesn’t hook up all that well
Might look into a mapping switch??? She doesn’t have that big hit off the bottom that I loved with the 525. I understand that they are trying to get tractable power but if I wanted that I would of bought a tractor. Has anybody else gone for a mapping switch???
Other than that she rode sweet. Some stalling issues that is probably rider eror.
But overall I’m am very happy with my new 500
MurphOctober 1, 2011 at 4:50 pm #209950
Congrats Murph
October 1, 2011 at 5:04 pm #209959Nice Murph. :woohoo: :woohoo:
It’s been a long time coming mate.
I think you can do the map switch mod without the $100 switch. I’m sure it’s just a wire mod. You would never use the softer map anyway.
We want action shots too. Shiny bike in the backyard pics are just showing off. :laugh:
October 1, 2011 at 6:19 pm #209961Murph , to my knowledge the map switch gives you access to the rain setting or softer. I didnt notice any difference when i use it. i also broke the button somehow. save your money or do the mod the cheap way without the ktm map switch.
congrats on your new Katie.
October 1, 2011 at 7:03 pm #209962Sounds good, only question I have is…….. What sort of bike have you bought?
October 1, 2011 at 7:43 pm #209951I believe it’s a KTM500.
Congratulations Murph, a well deserved upgrade. Will take a few rides for you to get cozy. Try a tooth higher on the front to see if the gearing change actually works for you? As others have said try playing with the wire before you buy a switch. I have a GasGas one on mine and I use it when it’s muddy wet and I’m rooted (about hr 6 of 7 on your rides).
Have fun eh!October 1, 2011 at 9:40 pm #209963Thanks for the ideas about the mapping switch, fella’s.
I will have to do some investigating
Axel, changing the front sprocket would be heaps easier, hope there is enough chain
That would be roughly the same as 3 and a bit teeth on the back wouldn’t it?
Shall try a 14 front on Tuesday
My 525 ran great with 14-50
This bike has 13-50
The box ratios are slitghly different between models, only the first few gears and there is not much in it
Cheers all
October 1, 2011 at 11:08 pm #209972Very nice Murph!!!
If the map switch operates the same as the 350, it is definitely worth having. The 2 position switch can be set to aggressive/standard or wet/standard. A switch under the seat toggles between the two.
I’ve only ever had mine set to aggressive/standard and there is a norticable difference between the two. Set to aggressive the engine seems to rev longer and harder.
I think there may be an aftermarket 3 position switch.
October 1, 2011 at 11:09 pm #209973Congrats Murph it looks sweet.
When’s it doing it’s first Murphsberg??
I reckon I’d be updating that bash plate :woohoo: :woohoo:
Kram
October 2, 2011 at 12:10 am #209974i now this bike is a different model but i found 14 52 good gearing on my 530 suited to murpghsberg riding 14 50 was suited to dubbo riding i went 14 52 spot on bit slow on the road but.nice bike murph bet it handles good there slim hay
October 2, 2011 at 12:29 am #2099523 or 4 tooth to 1 at the front, spot on. A 14 front will be a quick fix. Chain should fit.
October 2, 2011 at 9:54 am #209953Thats awesome Murph
Please tell us your going to be nice to it for awhile before you throw it into a murphsberg.
I had the thought of hooking my mapping wire up to my blinker switch, it’s a switch that is already there and not in use :unsure:
Congrats matePTW
October 2, 2011 at 10:26 am #209991nice bike murph, be about the only bike that would make turn back to a 4stroke, so when are you coming to stroud !!!
October 2, 2011 at 12:33 pm #209993Once I have a new rear tyre, bar raisers and the gearing sorted I will be straight into another Murphsberg. So by next weekend all should be sweet.
Had a bit of a read of the owners manual and it says nothing about the ignition mapping
The six day version has a switch under the seat that can be set. I’ll just wait intil tomorrow when can talk to the KTM shop dudes.
Hey husky
Unfortunately I doubt if I’ll be up your way before the Nundle bash but we’ll see what happens
MurphOctober 3, 2011 at 1:16 pm #209954Very nice Murph…. Won’t be to long befor you have it all set up!!!!
justo
