Next exhaust mod on the ‘to do’ list
Home Forums Yamaha Bikes Yamaha Bikes Next exhaust mod on the ‘to do’ list
This topic contains 4 replies, has 0 voices, and was last updated by  Anonymous 17 years, 4 months ago.
  • #95340
    I am in the planning phase of my next little homemade exhaust mod. It will be a series of aluminium “quiet” inserts for my modified Ducati muffler, installed on the wr450f, as seen in a previous post.
    It’s not that I think the new setup is overly loud for the bush, but more a case of experimenting to see if reducing the outlet size of the tailpipe, has any effect on the low down power and torque. It will have a secondary effect of reducing the sound level as well. I actually like having a big loud exhaust as it compensates for my miniscule dangly, wobbly bit.
    The current size of the Ducati tailpipe is 48mm ID. I plan to make inserts of 35mm ID, which is what the White Brothers muffler for my bike is . The others I plan to make at 32mmID, which is the YZ450 tailpipe size.
    There are two designs I want to use. One is a straightforward sleeve with a tapered leading edge.
    The second design will be a central hole with satellite holes drilled around the circumference. This one will be alot of fun to make, particularly the calculations required to figure out the equivalent area of a large single hole, using 12 smaller holes and medium size central hole.Plus marking it all up and calculating taper angles.
    I am just waiting to get some alloy bar, as I tried with steel hollow bar, but it was just too hard for me and my lathe to work with.
    #111570
    Hey Nigel ol mate,
    How’d you get on with your inserts? Did they work or did they fly out and break your neighbours window?
    #111571
    Nah Mick, they haven’t been created as yet. I still just need to get myself a length of suitable aluminium bar to do the job.
    I don’t think I will have them for testing at the xmas party, so I will bring up the standard muffler, just in case my home made system is obnoxiously loud.
    #112934
    Don’t worry to much mate,I get obnoxiously loud after a few beers.
    #112935
    Nice work Slug. You’ve got some fun little projects on the go there. If you still want a job how about you come do mine and I can work on bits for my bike all week? :laugh:
