Oil for XR600R????
Home Forums Tech Help Tech Help Oil for XR600R????
This topic contains 69 replies, has 0 voices, and was last updated by  Greg 17 years, 6 months ago.
Viewing 10 posts - 61 through 70 (of 70 total)
  • #107561
    Hey he did!!! the old fella is 12 inches long but I don’t use it as a rule. Boom boom.
    #107562
    Mick, I have the same big problem as you, but it’s nothing that can’t be licked.
    #107699
    IM glad im slow im not getting in front of you blokes:ohmy:
    #107563
    So what’s the verdict? Now that the clutch pulled that caper and got all hot on me, do I open the case and check the plates? The clutch seems to be working fine now.
    #107715
    Change the oil and filter, adjust the feel travel to spec and ride it Mick, buy a beta trials bike if you go in there again
    #107564
    Will drop the oil this arvo and see what story the filter holds.
    The XR was quite capable at getting through the track, as gnarly as it was, the main reason it over heated I believe was that it sat idling for some time pointed up hill while I waited for the track to be clear of other bikes.
    Anyone that has ridden an XR600 knows if you are on the side of a snotty hill, it is best to keep her running!!
    #107565
    shane
    Funny you should mention oils…
    When I had the XR I used synth oil, semi-synth oil, mineral oil…almst every oil at some point! But I changed it REALLY regularly, more often than not after every ride. When I pulled it down to put the 280 kit in it she was SO clean! I never adjusted the valves but did check them regularly.
    Now with the Vor? She gets new crap oil after every ride. I dn’t think I’ve ever put expensive oil in it, I can’t justify the cost since it’s changed so frequently. That thing also is still very clean with excellent compression and stable valve clearances.
    I’ll stick with cheap oil flshed through regularly.
    #107566
    Well said Shane,,Another way to look at things.. There is sense in that statement.
    Then again I just put one of Ollies’ fancy stainless fllters in the XR so I just went to the fish and chip shop and got some of their old oil.
    #107678
    chris
    maybe. might be wurth a closer look might have a dodgy spring :(
    #107534
    I dunno I just changed the oil and it looked a bit blacker than normal and the filter was good but I took it for a run and all seems sweet???
    Just one of those things I suppose.
