oil height forks
This topic contains 1 reply, has 0 voices, and was last updated by  Mark Drinkwalter 14 years, 8 months ago.
  • #100132
    pedro
    hi nick i have a tenere 660z 2010 am getting suspension pge from you .i wanna use motul what weight and what height in the forks please cheers pedro
    #204258
    OK Pedro,
    Here’s the goss… if you’re running standard springs, use extra virgin olive oil and fill them completely to the top. They are now 100% better than stock.
    Reality is if you use our V4S PD valve and heavier springs go 110mm from the top with 10wt and 25mm of pre-load.
    If you are using our V4S and haven’t brazed up the rebound holes use 15wt at the same height.
    If you get stuck, give us a call at the shop.
    ER
