This topic contains 16 replies, has 0 voices, and was last updated by Dean 16 years, 10 months ago.
April 28, 2009 at 10:10 am #96269
I am looking for an identical oil to Rotella 20- 40 or a location where i can get this oil? Apparently this oil has no friction modifiers etc, it’s just a plain basic mineral oil. if some one knows of similar id be intersted. Thanks.
April 28, 2009 at 10:56 am #131255Husky, Rotella T is not available in OZ it is a US universal oil, ie able to be used in both Diesel and Petrol engines. The best oil that is easily available and also recommended for Motor cycle use is Penrite HPR 15
Below is an extract from another forum and a reply from Shell, enjoy OllieI read on US forums that a lot of guys use Shell Rotella T, a synthetic diesel engine oil, in their 4stroke bikes and 2stroke gear boxes, apparently it is as good if not better than bike specific oils but costs a lot less. Has anyone got any thoughts on this?
This is the respose from a tech at shell when queried on Rotella
Thanks for the opportunity to respond to your inquiry, and thanks for your interest in Shell products. (and my apologies for the delay in responding)
ROTELLA T SAE 15W-40 and ROTELLA T Synthetic SAE 5W-40 are universal oils, meeting needs of many 4-stroke gasoline as well as most diesel engines. They have performance credentials (API Service Categories SL and CI-4 & CI-4 PLUS) for lubricating both kinds of engines. Consequently, ROTELLA T can be a good choice for four-stroke motorcycle/ATV engines.
It’s best to consult your owner’s manual for recommended oil quality. If your engine manufacturer recommends oil meeting any of these API Service Categories; CF-4, CG-4, CH-4, CI-4 & CI-4 PLUS, and/or SH, SJ, and SL, or any earlier but obsolete category, then ROTELLA T may be a good choice.
ROTELLA T does not contain friction modifiers that are added to many passenger-car-only-oils, and it does not comply with all requirements of ILSAC GF-1, GF-2 and GF-3 (the ILSAC oil specifications are often recommended by many gasoline passenger car engine manufacturers). That can be good for motorcycle/ATV use. Friction modifiers can upset wet clutch operation. And the ILSAC requirements limit phosphorus content. Diesel engines and other engines with highly loaded valve trains, as well as transmissions, need extra (compared to passenger car engines) extreme pressure wear protection, which is provided by an additive that contains phosphorus.
One negative might be where the engine manufacturer recommends oil meeting JASO requirements. Part of the JASO requirement limits ash content to 1.2%. Ash content of ROTELLA T exceeds this limit. Oil ash contributes to combustion chamber and spark plug deposits.
Best Regards,
Greg Raley
Tel: +1 281 544 8621
Email: Gregory.Raley@shell.com
Internet: http://www.shell.comI went through the same thing about 6 months ago cos all the US guys use Rotella in their Hi po strokers.
I emailed the same thing to Shell australia about 6 months ago. The follwing is what I got from Shell Australia:
1st Reply from Shell Australia:
Rotella T is a Canadian product and will not be coming to Australia. The Australia version is Rimula X 15w-40. Rimula Ultra is a better quality oil because it is synthetic. But it’s API performance grade is not as high. It all depends on what the vehicle’s API spec has too meet.
What are you planning to put the oil into?
2nd Reply from Shell Australia:
For diesel engine performance Rimula X 15w-40 would be equivalent to Rotella T. However Rotella T in a universal oil, suitable for both spark and compression ignition engines, which Rimula X 15w-40 is not.
None of Shell Australia’s high performance diesel oils (Rimula X 15w-40, Rimula Super, Rimula Ultra) are tested for spark ignition performance. As such we would not recommend using them in a motorcycle, regardless of whether they contain friction modifiers.
regards
Shell TAC
3rd Reply from Shell Australia:
I would like to assure you that I have examined the websites that you have forwarded to us. However, little of what is said on these websites applies to Shell products available in Australia. Shell USA has a completely different range of diesel engine oils to those available in Australia.While we have a Rotella range of oils (Rotella DD+ 40 and Rotella DD+ 50) in Australia, they are suitable for use only in Detroit Diesel 2 stroke engines, and as such cannot be compared to the American Rotella T. Rotella T is a universal (as opposed to diesel specific) engine oil, making it suitable for all types of 4 stroke engine (heavy duty diesel and both motorcycle and passenger car petrol engines.
I would like to reiterate that the high end diesel oils sold by Shell in Australia are all designed solely for diesel engine use and are not designed for, nor tested to meet any kind of petrol engine specification.
To answer your questions directly:
Rimula Premium (which is not sold in Australia) is not the same as Rimula Ultra. Rimula Premium is designed to North American diesel engine oil specifications (set out by Caterpillar, Cummins, Mack etc) , whilst Rimula Ultra (as sold in Australia) is designed to meet European specificiations (set out by Scania, Volvo, Iveco etc). Neither is better than the other, because they are design for different purposes.
In Australia, Shell Rimula oils are used in heavy duty, 4 strokes diesel engine, while Shell Rotella oil are used in 2 stroke diesel engines. Therefore they are not comparable.
Rotella T is not a diesel engine oil, it is a universal engine oil and therefore will be suited to all types of engines. Shell Australia’s high end diesel oils are diesel specific, and we strongly recommend that they are used for this purpose only. You may wish to re-read the note at the bottom of the following link:
http://www.rotella.com/qa/answerresult.php?rowid=81
Please be aware that none of Shell Australia’s diesel engine oil meet the API SL specification and as such may not be up to the challenge.
AFAIK rotella is not imported into Australia. It is a US based oil.
April 28, 2009 at 1:00 pm #131276Ollie wrote:
Quote:The best oil that is easily available and also recommended for Motor cycle use is Penrite HPR 15In who’s opinion? And why?
April 28, 2009 at 1:21 pm #131256i use Penrite enduro in my lc4, in the gsx 600. and now also in my ducati monster. i run penrite in my cars.
the back of the enduro bottle has a list of what penrite oil to use in what bike. their HD in harly etc. and what car oil can be used in certain bikes.
i used to run penrite hi-per 2t but they changed the branding of their 2t oils and don’t know what they make for high performance 2t’s.
one of the guys that used to work at the dealer where i adopted Katie from, used to test for Pentire, all their bike oils. he rode MX, Motard and trials, so he knows a bit about bikes, riding and what is needed from an oil.
but as long as you find an oil that is suited to your bike ( you can only be guided by what others say they use/ recommend) you basically have to find what you like/require, can be readily obtained and at a reasonable price.
personally i do not like the shell ( advance 4 from memory ) KTM were recommending for the 2002 4t range, my 640 was below the add about 300 kms short of it’s change due milage.
the penrite enduro has not failed me to date and i rarely have to top it up between changes, that’s why i recommend it. and it’s about 1/2 the price of the shell advance 4.
anyway that’s my sixpence worth.
April 28, 2009 at 1:25 pm #131315Recommended by the manufacturer for use in motorcycles,semi synthetic,cost effective have used it for years in my fourstrokes always did what I expected it to,never once was I concerned with the quality. (my opinion based on my experiences and what others have also said and experienced)
April 28, 2009 at 1:26 pm #131316Cheers xy-transit thats good
sounds like your onto a good thing, but I am wondering why “The best oil that is easily available and also recommended for Motor cycle use is Penrite HPR 15” who said it and why some many other people and manufacturers bother if thats the case :blink:April 28, 2009 at 1:31 pm #131318Ollie wrote:
Quote:Recommended by the manufacturer for use in motorcycles,semi synthetic,cost effective have used it for years in my fourstrokes always did what I expected it to,never once was I concerned with the quality. (my opinion based on my experiences and what others have also said and experienced)ollie
Oh ok thats makes sense cheers if it works use it I reckon. I use something else because different people told me its good and recommended it, but they never said it was the “The best oil that is easily available and also recommended for Motor cycles” but their recommendation was only their opinion :laugh:
Hope they dont tell you to jump off a bridge Ollie
April 28, 2009 at 1:37 pm #131320Trailboss wrote:
Quote:Cheers xy-transit thats good
sounds like your onto a good thing, but I am wondering why “The best oil that is easily available and also recommended for Motor cycle use is Penrite HPR 15” who said it and why some many other people and manufacturers bother if thats the case :blink:I am sure there are other easily available oils that do just as good a job, but they are OTT$. I was just giving an option that would be comparable to the shell Rotella T that is not available in Australia. Easily available re Kmart,supercheap most bike shops etc. in reference to your last part of the question, why do we have more than one brand of bike? options , personal preferences etc etc.
April 28, 2009 at 1:42 pm #131321Sorry for the slight Hi jack there Husky but the statement just couldnt be let go
There is another thread here where oil is discussed, its like tyres its opinion based which is why I sort of wont recommend a brand or claim its the best in the whole world ever.
There are lots of good oils on the market and very little separates them, go with what your hand book or dealer says, ask here but beware of the best in the world without in my opinion added because thats all it is.
Rat uses Motul as do I, its good, XY as he said use penrite and is happy, Crash uses Belray and so does Fathead I think, Chicken uses Motul, Mick uses I cant remember but can picture it and Moto uses whatever the KTM gods tell him lol
I am going back to my rum
April 28, 2009 at 1:54 pm #131322I think Mick uses Penrite
April 28, 2009 at 1:56 pm #131326Ollie wrote:
Quote:I think Mick uses PenriteWell he should I was told its the worlds bestest ever :laugh:
Yeah its the gas oil he uses, must be the 2nd bestest
April 28, 2009 at 1:58 pm #131327you Ijit:laugh:
April 28, 2009 at 8:20 pm #131328I use Penrite GAS 10, it was recommended to me by some local notorious engine rebuilders whos opinions I rate highly, it is designed for gas engines and other engines the run hot. ie big air cooled 4 bangers. They run it in their flat trackers and “high performance Harleys” (oxymoron).
It is also very cost effective at $130 for 20L.April 28, 2009 at 10:34 pm #131323Trailboss wrote:
Quote:I am going back to my rum
TBThat explains a lot:laugh:
April 28, 2009 at 10:52 pm #131324
AnonymousTrailboss wrote:
Quote:Rat uses Motul as do I, its good, XY as he said use penrite and is happy, Crash uses Belray and so does Fathead I think, Chicken uses Motul, Mick uses I cant remember but can picture it and Moto uses whatever the KTM gods tell him lolActually I’ve been experimenting with oils recently. After my research (see the other thread where I posted factual information based on the science of why an oil should work and not beacuse my mate told me to) I decided to try a Shell oil. It was actually quite good and I preferred it to the uber expensive Motorex stuff that KTM recommend.
I then tried Motul300V which I also found to be very good but is still on the upper end of the price bracket. I have now moved on to Motul8100 which isn’t very good and makes changing gears/finding neutral a mission after the first 100K’s. Motul 5100 that I tried was as good as the Shell and the 300V, although I find it hard to get hold of (I had to order it in).
At the end of the day, they have all done their job without nay major issues. Some feel better than others and others seem to hold up to the stress better. If you’re changing oil every 400Km’s then you can pretty much use any decent oil (non-friction modified of course), I think it’s all down to what you prefer
