Ollie new Ride 07 Gasser
Home Forums European Rides Ollie new Ride 07 Gasser
This topic contains 40 replies, has 0 voices, and was last updated by  Mick D 17 years, 4 months ago.
Viewing 15 posts - 1 through 15 (of 41 total)
  • #95347
    Well Ive gone and bought myself a near new 07 model Gasgas 300 Paid $7k for it I was feeling my age and riding like a gumby on my WR450 so it had to be another 2 stroker.
    Things Ive done so far prior to me riding it are.
    removed the blinkers and Horn
    fitted a perspex headlight gaurd
    Teflon taped the clutch and front brake perches
    checked the Sag (might need a new spring for my fat arse:laugh: )
    cable tied the speedo pickup wire out of harms way
    put some protective tape on the forktube staunchions.
    fitted pivot pegz
    I still have a bit more to do this will include:
    fit barkbusters
    make alloy bashplate
    make carbon fibre pipe gaurd
    make a protective plate for speedo drive pickup
    make a protective rubber cover for the sidestand where it hits the swingarm
    make the seat a bit more comfortable currently hard as a plank
    sought the jetting after Ive had a ride,might be running lean as it came from Oberon
    I want to get some clear 3m or thick contact to go over the plastics(any idea’s?)
    Fit Heavy Duty Tubes
    [img=http://xs233.xs.to/xs233/08456/07gasgas300879.jpg]
    #111644
    Ballards have clear 3m thick contact to go over the plastics I had it on my bike and chicken was good enough to test it for me my having a HUGE get of on my bike when it was new on a dirt road, just dirt road, not a 135 foot table top, it was a dirt road, anyway now thats out of my system I can recommend Ballards clear contact.
    Nick Gilbert
    looks trick mate….. can’t wait to snaffal a ride off you tommorrow! :P
    #111653
    I knew you would want a ride!:laugh:
    As if your shed isn’t full enough.:blink:
    #111645
    luke watson
    you won’t be sorry they are a good all rounder. have you had your side stand spring mounting point changed
    #111662
    Well blow me over with a feather!!! Gasit has had something to say!! Welcome to the forum matey. Hey Ollie this is the guy to talk to about Gas Gas 300.
    #111663
    No mate,not yet what is the go there? I know it is a shit setup the way it rubs on the swingarm:(
    any advice will be warmly recieved
    cheers Ollie
    #111661
    yeah and I still have to pick up the IT250!:laugh: I will be advertising a few bikes for sale real soon. 04 WR450,05 KXF250,99 KTM380,99KTM300.
    cheers Ollie
    #111664
    cheers Ollie
    You’ll be able to see first hand as Gasit will have his at the Xmas party.
    #111646
    luke watson
    the rubbing is possibly caused from a bent bracket or play in bolt.for the spring mount try getting the side out of a chain link enlarge one hole to the same size as bracket hole then bolt on with bracket bolt extending outwards. hook spring in other hole.
    #111705
    Thanks Gasit,the springs came off about 5 times today and was really pissing me off,in the end we used a innertube rubber strap to keep it up out of the way.
    Other than that and a need to jet the the thing properly I was really impressed,these things carve up the tight stuff!!
    any jetting recomendations?
    cheers Ollie
    #111708
    I rode Gasits Gasser today,those things go good!! Gasit was frigging around with jets today so I reckon he can help you out Ollie. Maybe he will tell you about the smaller base gasket while he is at it. Come on Luke, spill your guts.
    #111711
    Im all ears:laugh:
    #111647
    luke watson
    i am running a Norside power valve cover as well as after market needle which runs a little leaner in the mid range.don’t recommend running a thin base gasket unless fit and racing.they come with a selection of base gaskets. better stick to one down from standard.i will check up on needle size and let you know.running a 38 pilot and a178 main.
