Home › Forums › Your Garage › Operation ‘IT’ is a go!
This topic contains 45 replies, has 0 voices, and was last updated by Stuart 12 years, 5 months ago.
August 22, 2012 at 1:11 am #228251
That’s what I would do Moto. Not sure if that’s the right money (sounds fair to me). I have to do the same to the frame on my WR.
Rocket’s a welder!
Too far away to help though.August 22, 2012 at 2:30 am #228073A good paint job on the frame will set the tone for the rest of the project as well.
August 22, 2012 at 2:57 am #228258For the amount I spent in new parts I may as well have bought a new bike
I’ve got a company in Sydney who will anodize my rims black for $80 though. Pretty good except I have to sand them down
and then get them to South Sydney….doh!!Getting the good swingarm off the other bike is royal pain in the ass! I’m a bit stuck as to what to do with pistons, rings and bore sizes too
August 23, 2012 at 9:45 am #228259So I’ve been pondering the piston, rings and bore situation today and have ended up buying a manual for the bike so I can find out what the recommended ring gap and piston-bore clearance should be.
Measuring up what I have I could take one of the pistons and use it for the other motor, replace the rings with the correct size and have the motor bored to suit the 1mm o/s from factory.
Anyway, whilst checking the ring end gap I notice that guy the had the bike before me has obviously mis-treated it (this was evident from the state of it anyway) as the ring end gap was 6+mm!! It would have had phark all compression and ridden like a slug!
He had issues getting it started when I bought it. With this and the fact you can see light across the length of one whole reed petal I think this would explain it!
Below is comparo of another ring from the other motor. Still a used ring but see the difference in thickness and see how the thin one is ovalized too:
Seat cover came off today, looks like someone has had a million goes at putting the previous one(s) on as there is no end of rusty staples in it. I’ve probably got hepatitis now.
Frame and swingarm are ready for shot blast and paint. I had to get the angle grinder on the chain to get it, and subsequently the swingarm off.
Wheels are having the tyres removed at the bike shop (haha
) and I will pull the wheel down when I get them back. I then have to sand and tart up the rims ready and get them to Sydney for anodizing.Top triple clamp is sanded and primed, awaiting paint.
Some other bits have been given the acid dip treatment with varying levels of success. Carbie has now gone almost black and furry. Might need to add a new Mikuni to the shopping list.
I’ll replace bolts where I can with high tensile Supercheap auto jobbies, haven’t decided of I’ll go the SS ones or the standard ones. I don’t like the bronze colour of the stock bolts, what ever happened to BZP???
Sanding the tank down is nothing short of nightmare too.
Hopefully the manual tells me what the weight and quantity of fork oil I’ll need as well as the motor specs.
August 23, 2012 at 10:14 am #228334Watching this thread with interest. It is exactly what I planned to do with my old IT, until I realised it wasn’t gunna happen for a few years and I sold it. Same model as your too Moto.
August 23, 2012 at 11:38 am #2283356mm is huge Moto :ohmy: You may have measured it the wrong way mate. You did measure it in the bore didn’t you? Use the piston to put it into the bore, square it with the piston about half an inch in. Maximum would be about 18 thousands of and inch I would have thought but your manual will have it mate.
I like this thread well done what a huge job. Am looking forward to it being finished will pull the 370 out when your going if you want to do some long track or short track VMX style
Found this after I posted hope it helps it helps it’s Eric Gorr and you may have his stuff?
The best way to know if the rings are worn is to measure the ring end gap. Put the ring in the cylinder and use the piston to push it down about 1/2 inch from the top evenly spaced. Now use a feeler gauge to measure the width of the ring gap. Normally, the maximum gap is 0.018–0.025 inch.
Ring End Gap rule of thumb
Ring end gaps for conventional rings…General rules of thumb
top ring .0045″ to .0055″ per inch of bore diameter (example 4″ bore x .005″ = .020″ end gap.
Second ring .0055 to .0065″ per inch of bore diameter (example 4″ bore x .006″ + 0.024″ end gap.
Oil rings are a minimum of .007″ per inch of bore.
Total Seal top rings are fitted at .0075″ to .0085″ per inch of bore.
August 23, 2012 at 11:34 pm #228339Cheers TB, I hadn’t seen those numbers but to be honest I didn’t bother looking as I have bought the service manual so I can stick to what it recommends.
I measured the ring gap exactly as you described about 20 mm in from the bottom and about 10mm down from the top (below the normal stopping point of the piston rings at TDC).
It was 6mm, no joke! I had the feeler guages out ready to measure the gap as well
I put the other ring in (the one pictured) and it’s too big. I expected it would be but was good to check my calcs/measurements.Using the rules of thumb above the min top ring end gap should be somewhere around 0.3mm and with the bottom ring at 0.35mm.
Anyone know a good engine mob on the Central Coast or Newcastle? I could just take it to a machone shop but would rather someone who knows what they’re doing.
Sweet, the new chain has just turned up, first of many parts! I’m off to order a new carby……….
August 24, 2012 at 12:11 am #228349Good job there MOTO, lots of work to put in, makes me want to pull my YZ80s out that I have in a million bits in the shed, but just don’t have the time.. one day..
August 24, 2012 at 12:33 am #228350Just got in contact with a mob at Somersby called ECS Engines and had a chat with the guy who seemed to know his stuff. I’m going to drop the head and other bits off to him after it’s been snadblasted and he’ll proprley measure the bore for me.
From there I will know if we can keep it 0.75mm ovversize or if the bore is ovalled badly enough to take it out to 1mm. To measure it up, bore and hone (which is the worst case) is $70…..nice!
I think I’m just going to buy a new piston kit now, seems pointless doing all the hard work to throw some old piston back in there for the sake of a $100 bucks.
August 24, 2012 at 3:37 am #2283526mm wow. You should measure with screwdriver tips!
I pulled down my 12hp briggs ride on motor last night. Similar end gaps, bore out of round and piston to bore clearance was nearly 1mm. Yikes.August 24, 2012 at 4:36 am #228357Yeah but I bet your Briggs goes harder than the IT
August 24, 2012 at 11:40 am #228362Maybe, but I know it ate more oil than your IT thats a fact
September 15, 2012 at 7:00 am #228381Mick….the IT250 is still a work in progress..
and the peanut butter polishing does work!!!Ive had a heap of health problems over the couple of months had led to a slowdown on the builds on both the IT400F and the IT250.
September 24, 2013 at 10:56 pm #228074Timeless model, the old IT.
I had a 175J when I was a kid in Bellingen and it was awesome.
One of the things I HATE about living in suburbia is no big shed to spread out all my half arsed projects.
Otherwise I’m sure I’d have a couple of IT’s on the go.
September 25, 2013 at 9:32 am #250134Wow .What happened to this project Moto.Did you finish.You have had a year to do it.
