Out of alignment
This topic contains 24 replies, has 0 voices, and was last updated by  glenn 16 years, 9 months ago.
Viewing 15 posts - 1 through 15 (of 25 total)
  • #96609
    When i come off the suzi the other week i thought i bent the handle bars, however after i replaced them the stearing still seem out of whack,, any suggestions as to what this may be?
    #139337
    You have just twisted the forks in the head stock Boony. It’s a bit like what used to happen in the push bike days. Just lock the front wheel against something a pull them back into line. I had to do the same thing today, I was able to put the front wheel in between 2 trees and push on the bars to line them up.
    #139346
    I dont have to loosen anything??
    #139348
    You could if you wanted to, it would make it easier to do but I never have, I have seen some people just pull up next to a tree and bash the front wheel against it by turning the bars to straighten it up and I have even had a guy get me to kick his wheel while he held the bars to fix it.
    #139338
    yeah i’d loosen the triple clamps just enough to realign it. i thought the same after my bro cart-wheeled katie.
    i found the bar support/mount clamps were twisted too. put a punch in each hole and twisted them back to where the should be.
    so that may be a possibility too.
    #139349
    if you are at home just loosen the bolts on your fork clamps while your bike is on a bike stand and straighten it up and do the bolts back up.prably would not hert to loosen your front wheel of and bounce up and down on it a few times to aline it to than do it up again
    #139347
    When out on the trails do what Jeffro did and it will get you going again, but the way to get it back to perfect again is to put the bike on a stand and get the front wheel up off the ground, undo all fork bolts in the upper and lower tripple clamps, then spin the forks in the legs to make sure nothing has bound up, being careful of the height adjustment not moving, then tighten up one side top and bottom and as long as you have no bent upper fork legs, then you can be sure the top and bottom are in line, you then tighten up the other side and now it is all square, just be sure not to tighten too much as they wont twist in the clamps but bend, Hope that helps:)
    #139350
    do I loosen top and bottom clamps????
    #139351
    thank you all first class information and directions as normal.
    Will give it a go in the morning and repot the outcome….
    #139352
    Morning???….pussbag!!!!………….KTM Riders would do it now before going to bed:laugh:
    #139353
    KTM riders up here also dont turn up like they say they will, but Boony will do it in the morning :laugh:
    2 x tinlids to bed then maybe
    #139355
    No TB I turned up OK , the bastard wouldn’t start remember
    #139357
    No No Rat, Mick’s shed last night? Remember the ice, our phone call :laugh:
    Sorry Boony, let us know how you mate :blush:
    #139359
    all good keep going :)
