This topic contains 14 replies, has 0 voices, and was last updated by Shane Cosgrove 12 years, 6 months ago.
August 24, 2013 at 9:47 am #103174
Giving the bike a wash today and after last weeks Nav ride I thought it might be an idea to clean my pre filter on the Tiger.
Took the seat off to get to it but it seems to disappear under the tank.
Do I need to take the tank off to be able to remove it? Mr Squiggle, any ideas? Anyone?
Wigster
August 24, 2013 at 10:30 am #248584I can do the adv Moto one without taking the tank off but it fiddly (aka prick of a job)
August 24, 2013 at 11:04 am #248585Wigster wrote:Giving the bike a wash today and after last weeks Nav ride I thought it might be an idea to clean my pre filter on the Tiger.Took the seat off to get to it but it seems to disappear under the tank.
Wigster
Did you install the unifilter wigster?
August 24, 2013 at 11:15 am #248590No, it was done at the dealers. This is where I miss my KLR. Change oil and filter, clean air filter, 20 minutes max.
It seems like a long “sock” type of arrangement which I think replaced the snorkel. I can’t see any way of getting to it without the tank off, (which I haven’t done on the Tiger yet).
I suppose it will be ok as it is a pre filter and not that dirty but I like to keep on top of maintenance stuff if I can.
Wigster
August 24, 2013 at 11:43 am #248591tractors got one of these might be worth pm him and ask what hes been doing
August 24, 2013 at 2:32 pm #248592Its not a tank off job wigster, there is a bracket at the back of the tank you have to take off, just a couple of bolts, the pre-filter is just a rubber insert so you basically just work it backwards out of the airbox, clean, oil, replace and put the bracket back on.
Ill do mine tomorrow and take a couple of pics or a vid for you.
Its a 10 min job
August 25, 2013 at 5:12 am #248597MrSquiggle wrote:Its not a tank off job wigster, there is a bracket at the back of the tank you have to take off, just a couple of bolts, the pre-filter is just a rubber insert so you basically just work it backwards out of the airbox, clean, oil, replace and put the bracket back on.Ill do mine tomorrow and take a couple of pics or a vid for you.
Its a 10 min job
That would be very helpful Mr Squigg.
Just had the battery out to check the drain hole not blocked and to look at doing the main fuse mod and I think I know which bracket you mean.
Wigster
August 25, 2013 at 5:31 am #248610http://www.youtube.com/watch?v=7CTbT6HWJn4
here ya go mate.
August 25, 2013 at 7:23 am #248611Thanks for the video. I have been wondering what to do about the Air Filter on my Tiger.
Where do you get the per filters from.
August 25, 2013 at 8:28 am #248618http://www.uniflow.com.au/contents/en-us/d341.html
No probs, blathered on a bit
August 25, 2013 at 11:46 am #248625That’s brilliant Mr Squiggle. Thanks for taking the time to do the vid. I’ll be getting it done tomorrow.
Are you going to do the main fuse mod?
Wigster
August 25, 2013 at 12:11 pm #248638Wigster wrote:That’s brilliant Mr Squiggle. Thanks for taking the time to do the vid. I’ll be getting it done tomorrow.Are you going to do the main fuse mod?
Wigster
I thought about it Wigster but so far have simply opted to pack a couple of spare fuses, I might see how it goes, once you know about the problem its pretty easy to manage, dont wash the underseat area unless the drain hole is working. Thinking about it, its probably alot simpler to just drill an extra drain hole in the bottom of battery box, if the fuse doesnt get drenched its unlikey to ever need replacing.
August 26, 2013 at 10:03 am #248619Tractor wrote:Thanks for the video. I have been wondering what to do about the Air Filter on my Tiger.Where do you get the per filters from.
I got mine from Northside Motorcycles in Artarmon.
Wigster
August 26, 2013 at 10:10 am #248640MrSquiggle wrote:Wigster wrote:That’s brilliant Mr Squiggle. Thanks for taking the time to do the vid. I’ll be getting it done tomorrow.Are you going to do the main fuse mod?
Wigster
Good thinking Mr Squiggle. Will do the same. I was a bit concerned about warranty issues too. You know what dealers are like “My swingarm has broken in half”. ” Ah, that’s because you’ve done the main fuse mod, sorry no warranty claim for you”.
Wigster
August 26, 2013 at 10:22 am #248683Wigster wrote:MrSquiggle wrote:Wigster wrote:That’s brilliant Mr Squiggle. Thanks for taking the time to do the vid. I’ll be getting it done tomorrow.Are you going to do the main fuse mod?
Wigster
Wigster
While your at it wigster I recommend doing something to help the centrestand spring, had heard of them letting go and mine did the same on the last ride (Hence all the red rope in the video, thanks to the old bull who packed that, not sure who it was)
No good landing on the center stand coming off a jump or sharp crest at speed :unsure:
I am going to replace the spring and make up a rubber tie system to solve this issue so I dont end up on my arse, ill let you know what I come up with. Its either that or just dump the damn thing, if only it didnt make servicing so easy
