Home › Forums › Bike Preparation Tips › Bike Preparation Tips › Preventing Flats
This topic contains 14 replies, has 0 voices, and was last updated by Anonymous 17 years, 4 months ago.
November 15, 2008 at 1:23 pm #95381
Getting a flat in the middle of the Bush can be a real pain in the arse this is copied and pasted from another website that may prove helpful
cheers Ollie:laugh:
I had a fantastic run with no flats for years……….. then it all happened, withing 2 rides I had 4 flats, I couldn’t believe it!!!!! Two of them (on seperate rides) were in almost the exact spot. Since then I came up with the following:1. I run heavy duty tubes (well worth the money)
2. When, or should I say if you get the chance, double skin the tubes by splitting an old tube and placing it as an outer liner in your wheel.
3. Carry spare tubes, I currently carry an 18 and a 21, BUT you can get away with a 21 or a pair of 21’s as you can run them in the rear (yes I have done it to get out of trouble)
4. METZELER levers are the BEST!!!! ’nuff said!!
5. I carry a 35mm film canister (yes the camera type) and have it full of dish washing liquid and tape it up to be doubly sure none leaks out. This is to assist in getting the tire on and off.
6. Also as backup I carry a small puncture repair kit, the style they sell in bicycle shops. While not 100% ideal they can do the job if you have time.
7. I carry a telescopic bicycle pump, the kind that they sell for Mountain Bikes. These mean a bit of effort, but they perform the task. Also a fact that is not that well known at times is that the CO2 cannisters don’t usually blow up an entire wheel i.e. you have to use more than one to get adequate pressure, and a pump is a once off cost.
8. A Gauge takes up little space but can be somewhat more accurate that the “feel method”
9. Also despite the fact that you lose a little handling, when running in rocky or hard terrain I bump the pressures up to avoid puntures.
10. Tighten your locknuts up against the valve caps, this stops the tube self destructing if it moves around!!
11. Duct tape makes a good inner liner (the liner that covers the spoke ends)
12. I have heard that some people carry 4 or more large hose clamps to put around the tire and rim to secure it in order to limp the bike home. ( I haven’t tried this though )
I’ve had little to no problems since I’ve implemented these measures.
My next step is trying Mousse tubes.
John K.
Notes on Re-occuring Flat Trouble – By Kloudkicker (from DRN forums):
When you get a flat, it’s always a good idea to take a minute and figure out why you got the flat in the first place and go from there.
** Before you pull the tube out of the tire (and/or the tire off of the rim) use a marker or yellow tire crayon to indicate how the tire/tube/rim were arranged while together as a unit. This will help you locate where the trouble was after you locate the puncure(s) on the tube.
**Puncture Flat:Make sure you locate where the object came thought the tire & that the object is no longer there. Even if you do not see or feel anything, use a small phillips screw driver(punch or something close) and push it through the hole. Thorns, especially, have a nasty habbit of hiding in the rubber until their next opportune moment to bite your tube.
**Snake-Bite Flat: Indicated by a pair of puctures on the rim side of the tube. This is normally(but not always) an indication of not running a high enough tire pressure for the riding conditions (like really rocky terrain or traversing rocks with sharp edges). I had a buddy who used to pinch-flat on RR tracks CONSTANTLY but would gripe that they were sucky tubes. Not quite.
**Blow-Out: If the tire looks fine, but the tube looks like it just caught a grenade. My first guess would be that you over shot the triples again Normally caused by an excessively high impact on the tire.
Other factors can be:
# Too high of a tire pressure
# Faulty tube
# Pinching the tube while remounting the tire(weakens the tube and it blow-up at a later date)
# Old Tube calling it Quits.**Spoke Puncture: Indicated by a single hole on the rim-side of the tube. If your wheel is not double-walled(ie: the tube rests against the spoke nipples) this can be a factor for you. If the wheel has been ‘brought back form the dead’ or an slightly longer spoke got put in because it’s what you had available, some spokes may be poking into the tube. The nipple itself can wear thru the tube also if not covered. I strongly recommend using heavy cloth rim-tape or hockey tape on the rim as a barrier between the rim and the tube(even if you do have a double walled rim). Rim tape will do it in one lap. 2 laps for hockey tape. Rubber rim liners move around on you when you least want it and lesser types of tape will wear thru faster than you might think.
**Nipple Hole Bite: Indicated by a ~1cm circle on the rim-side of the tube(double walled rims), the edge of which has the hole in the tube. Either you’re not using rim tape or your using some form of substitute which isn’t quite good enough. Keep in mind that the air pressure in the tire is going to try and push the tube into those little nipple holes if it gets a chance. As the tire and tube flex around, the edges wear through the tube. Heavy rim tape will prevent this from happening.
I think that covers the biggies.
If you have reoccurring trouble with pucture flats, I would strongly reccomend a tire liner. I’ve had really good results with them. Double tubing made the bike feel funny to me so I don’t use that method. I do know a few people who love doing that though. Personal preferance.
November 15, 2008 at 1:31 pm #112257All good advice there Ollie well done.
I have one thing to say, Mousse Tubes, no levers, no valve nuts, no rim locks, no hassles
NO DENTED RIMS
Good work again Ollie
November 19, 2008 at 4:03 am #112258
AnonymousThis is an interesting concept for dirtbike wheels. This style of internal beadlock has been successfully used in 4wding for many years, but it the first time I have seen it for dirtbikes. Apparently there is something similar for mountainbikes already in common use. According to what I have read the 18″ version STILL isn’t available yet, as there have been some teething problems.
November 19, 2008 at 4:22 am #112468Yeah Slug, Ballards have been flogging them now for quite a while now, they only have 19’s Ballard was telling be they tested them and they are lighter and can be run flat because the tyre is held on the rim
Check it out
http://www.ballards.cc/Text/1202883547349-7554/pC/1202869851119-8610/CATALOGUE-2008
November 19, 2008 at 4:24 am #112469Hey Slug, do you remember thise balls they tried, they filled the wheels up with greased balls years ago?
November 19, 2008 at 4:26 am #112470Greased balls???.That happened to me in my apprenticeship..bastards!!
November 19, 2008 at 4:31 am #112472November 19, 2008 at 4:34 am #112471
AnonymousTrailboss wrote:
Quote:Hey Slug, do you remember thise balls they tried, they filled the wheels up with greased balls years ago?I sorta remember something like that. I also remember balls you stuck in your fueltank.
Next they will be coming up with balls with numbers on them, that are tossed around in a big machine and randomly selected. Knowing the way that Aussie love to gamble, they could probably create a market where people try to guess what the numbers balls selected from the machine would be. Maybe there could be some sort of prize money pool. Nah, the more I think about it, it’s not really feasable and wouldn’t catch on in the wider community.
November 19, 2008 at 7:46 am #112473
Anonymousmicknmeld wrote:
Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!Mick,
If ever you need to remove grease from your balls, the best thing to use is either Deep Heat or Dencorub. Works like a charm.
November 19, 2008 at 9:25 am #112489slug wrote:
Quote:micknmeld wrote:Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!Mick,
Petrol is also good I hear???:ohmy:
November 19, 2008 at 5:29 pm #112474
Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!I just did a little sick in my mouth.
November 20, 2008 at 4:48 am #112513Steve We want Moto back wrote:
Quote:micknmeld wrote:Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!I just did a little sick in my mouth.
Did you swallow it back down like a man?
Or are you a ‘spitter’???
November 20, 2008 at 5:11 am #112598shane_vor wrote:
Quote:Steve We want Moto back wrote:Quote:micknmeld wrote:Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!I just did a little sick in my mouth.
How did preventing flats degenerate into this dribble?
November 20, 2008 at 6:03 am #112475micknmeld wrote:
Quote:Greased balls???.That happened to me in my apprenticeship..bastards!!You started it Mister D
November 22, 2008 at 9:49 am #112607
AnonymousI concur Mick, your greased balls comment brought the whole thread into ruin!
I did find it somewhat ironic though that in my short riding time I have only ever seen two punctures. Both were by Ollie (the original thread poster) and both in the same ride! :laugh:
