Home › Forums › Motard Forum › Motard Fourm › Project Motard DRZ400
This topic contains 206 replies, has 0 voices, and was last updated by Anonymous 16 years, 3 months ago.
October 20, 2009 at 7:29 pm #157422
WikdBeemer wrote:
Quote:What’s happening KD?
Surely the graphics have arrived?
How long does it take to put them on?
I am busting to see it.
Oh the anxiety of it all :silly:Mid November it will be finished and displayed I believe WB
October 20, 2009 at 7:56 pm #157424:ohmy: I dont know I can wait that long.
Make it faster TB, pull something out of your magic hat pleeease.October 20, 2009 at 8:30 pm #157425If it helps I have seen the graphics and the work Kylie and Tee n Cee signs have put into designing them is a credit to all involved.
Calm down and have a lay down Bemmer is all good
October 21, 2009 at 9:21 am #157426
AnonymousWikdBeemer wrote:
Quote::ohmy: I dont know I can wait that long.
Make it faster TB, pull something out of your magic hat pleeease.:blink: You think you can’t wait that long?
HOW DO YOU THINK I FEEL? (Yes I am shouting) :laugh:
The graphics are going to look absolutely super special. But yes we all have to wait because the bike will be put back together mid November. BTW I am not applying the graphics to the plastics. Tee n Cee till do that for me because if I did it (or if anyone attempted it) I think it would be disasterous.
I do have the images that Tee n Cee have sent through of the graphics but I am purposely holding off on posting them because you need to see the final result to get the full impact, I think anyway.
October 21, 2009 at 11:42 pm #157540Yes I have to say Kylie and Craig at Tee n Cee have done a great job on the graphics and the wheels look very very horn
October 23, 2009 at 2:05 am #157584for the sake of sounding like an uneducated uninformed goose, I’m gunna ask it anyway.
What is the difference between the normal DRZ and a Motard one ?
Feel free to snicker and giggle, I can take it.
But I know the molecular structure of the South African Burrowing Green Knat, do you? :unsure:
I dont really but I like people to think I’m educated :S :blush: :blush: :dry: :S :unsure:
October 23, 2009 at 2:11 am #157715JAK wrote:
Quote:for the sake of sounding like an uneducated uninformed goose, I’m gunna ask it anyway.What is the difference between the normal DRZ and a Motard one ?
Boy am I glad some else asked that question first???
well done Jak
October 23, 2009 at 2:11 am #157716
Hi Jak, I am not actually sure but I reckon that TB would know.
October 23, 2009 at 2:14 am #157717
AnonymousActually one thing I do know is that the motard version has pillion pegs :angry:
October 23, 2009 at 2:21 am #157719KylieD wrote:
Quote:Actually one thing I do know is that the motard version has pillion pegs :angry::laugh:
There you go Boony, now we can dink each other. :laugh: :laugh: :laugh: :laugh:
October 23, 2009 at 2:37 am #157720The only difference I think would be the wheels, the rest would be the same.
except for the pillion pegs.
October 23, 2009 at 2:42 am #157721Motard one means you have a motard DR like everybody else, Kylie’s mean she is an individual with a far better bike build to suit her the way see wants with everything she wants and nothing she doesn’t
October 23, 2009 at 2:51 am #157722Easy answer in the end. Thanks for that.
This is me and Boony out riding.
October 23, 2009 at 4:32 am #157724The 17 inch wheels and tyres is the most obvious but there are a few more differences between the DRZ400E and DRZ400SM.
The bikes are basically the same but the SM has a de-tuned version of the E motor, why they de-tune it for the road I don’t know.
The SM has milder cams, a thicker base gasket for less engine compression, a CV carby instead of the flat slide and a smaller header pipe.
The E also gets better suspension. The SM gets an inverted fork which at first would seem better but they are very basic forks with only preload adjustment and NO compression or rebound adjusters.
The SM shock has preload adjustment and low speed compression only and no rebound adjustment. The E has high and low speed compression and rebound. The SM also has less travel front and rear. All up the suspension on the E is far better than the SM.
The rear swing arms are also different, not sure if they are different lengths but the rear wheel adjusters are different.
I personally think if you want a motard DRZ400 your better of converting an E than buying the SM. All you need for the E is the 17 inch wheels and bigger brake then you end up with more power and better suspension then a standard SM.
To get a SM up to E spec would cost a shitload more and the SM is more expensive of the show room floor to start with.
October 23, 2009 at 4:55 am #157758
AnonymousScotty wrote:
Quote:The 17 inch wheels and tyres is the most obvious but there are a few more differences between the DRZ400E and DRZ400SM.The bikes are basically the same but the SM has a de-tuned version of the E motor, why they de-tune it for the road I don’t know.
Thanks for that Scotty!
I was going to put a post on that I thought that the suspension would be better on the E than the SM however I am just a girl so I wouldnt have had a clue whether that was correct or not. Good suspension is really important to me.
