pw50 oil injection cable
Home Forums Tech Help Tech Help pw50 oil injection cable
This topic contains 2 replies, has 0 voices, and was last updated by  alan 16 years, 6 months ago.
  • #97099
    does anyone now how to set it fitted a knew cable a while ago but did not see any marks on the oil pump so just gave it heaps .runs okay but uses a lot of oil would like to set it up standard
    #150973
    Rocket, I have two PW50’s here in the shed. One with the oil pump connected and the other disconnected and running on premix. The one running on pre mix which is incedently 19 years older than the other, runs heaps better.
    If you want to disconnect the pump,block off where it goes into the carbie and put a loop of tubing around the pump from the inlet to the outlet,effectively creating a circuit that the oil that is in the pump still, can circulate and keep the pump lubed just in case you want to use it in the future.
    If someone cant help you out with the pump settings here, try one of these sites.
    http://www.pwonly.com
    or the Pee wee section at Thumpertalk.
    #150980
    where are all the two stroke guns.the old pipes gummed up to will fix him up tomorrow bump
