Radiator Guards/Braces Fitted
Home Forums Kawasaki Bikes Kawasaki Bikes Radiator Guards/Braces Fitted
This topic contains 2 replies, has 0 voices, and was last updated by  Chris 17 years, 6 months ago.
  • #95005
    Hi All,
    Put some Unabiker radiator guards on the KLX, not an overly hard task, no draining of coolant or removing hoses etc, the only issue I had was some of the bolts that shipped with the guards were too long, some of the ones that were 25mm I had to swap for 20mm bolts, especially the ones that go into the tank, I felt if I tightened them any further I was going to put a hole through the tank.. Anyway a couple of pics below..
    #106948
    Nice Job Mate
    #106978
    Thanks KTM, just in case anyone else stumbles on this, the rear of the front guard now rubs on the clutch cable, I have found by adding a couple of washers under the bolts it will pull it away so it no longer rubs.
