Home › Forums › The Adventure Moto Riding Forum › Dual Sporting / Adventure Riding › Camping Gear / Product Reviews › Re: What camping gear works for you ?
This topic contains 7 replies, has 0 voices, and was last updated by alan 14 years, 4 months ago.
June 5, 2011 at 12:51 am #99991
I purchased a Thermarest Prolite Plus Small 3/4 Self-inflating Mat
Slightly thicker at 3.8cm and with a higher warmth rating than the Prolite 3, this mat is the perfect choice for those who are willing to carry the extra few grams for a better nights sleep or for those going to colder climates.
The Prolite uses innovative materials and new shape reduces weight by 25%. Die-cut foam allows for smallest roll size ever. This mattress is engineered for extreme alpine climbing, adventure racing and long-distance backpacking when reducing weight and bulk are paramount.
This high quality self-inflating mat is high density, abrasion resistance coated. The mat Bottom features an innovative, sticky-dot, non-slip surface is also anti-fungal and water resistant to maximise comfort and thermal efficiency. It also has a high performance screw treaded high flow
SPECIFICATIONS:
Dimensions: 119 x 51 x 3.8cm
Packed Dimensions: 10 x 28cm
Material: Slip resistant polyester, Nylon Base
Weight: 480 grams
Core: new urethane die cut foamFEATURES:
Made in USA
Patented foam perforation technology has enabled the creation of a mattress that is 20% warmer than previous Prolite 4 model
Low volume tapered design
Ultralight: innovative new materials reduce weight by 25%
Compact: tapered ergonomic design rolls up super small.
Technically advanced fabric and foam make this pad 30% lighter than an UltraLite™ pad
Fabric: Slip resistant polyester top, Nylon base
High quality adventure hike mat
Cored construction reduces weight and promotes quick and easy inflation/deflation
Water repellent coating extends durability
Lifetime WarrantyI have found a different bag and a way to roll it up to half the size they advertise
Cost $149 rating 8/10 only because it’s smaller than I thought not a fault of the product really
July 19, 2011 at 3:40 am #202617Gday all,
I bought a one man tent shown in the link below. In a nutshell, this tent packs into a size of 400mm x 150mm dia including steel poles. I have been through Nth QLD wet season torrential rain in one and only been damp due to condensation or slight weeping throught the seems. I use it with a sleeping bag but if i use it when its cold, i will use a rated cold weather bag or have enough piss to nmb me up before sleeping so i dont feel the cold too much.
Prior to using the tent, i set it up at home and set the guy ropes up, to allow an easy setup whilst out in the scrub.
I bought mine for $110 off the net, including delivery and a pillow of some kind that never gets used.
http://www.darche.com.au/tents/hybrid.html
Cheers ryno
July 19, 2011 at 11:52 am #202618Off road camper trailer, water, fridge, hot shower.
:laugh:hatto
July 20, 2011 at 12:52 am #205122$80
and a motel bed
even a pub bed
I like taking my avatar as a pillow tooB) :woohoo:
spose i should get back into camping one day
July 20, 2011 at 1:06 am #205181nice pillow bob
July 23, 2011 at 2:41 pm #202619hi tb where du buy the mat from ?i bought a tent swag for $120 from anaconda.has a 6cm matress rolls up quite small 500cmx250cm.just going back to the 12v accesory you added to the tenere cant find one over here for less than $40.getting bloody expensive living here .maybe might move over that way your riding terrain shits all over what we got here sand sand sand and some sand cheers pedro
September 3, 2011 at 12:33 pm #202620Tent wise I have a Blackwolf Mantis 2. HTF you can sleep 2 in it is beyond me as it’s pretty tight for one. I’m 6’1 and wouldn’t want to be 6’2. Very light and very strong however. Packs down to about 1/4 of a bed pillow size which I’m happy with.
http://www.blackwolf.com.au/adventure1000078/mantis-ii/Lie on a BCF self inflating matteress with a 35yo down sleeping bag. No probs here
Cooking is still being sorted out. Currently burgers and pub grub. Hopefully on the Wyanlgala ride I’ll get to see some setups before I lash out. some are pretty $$ so I want to get it right.
October 7, 2011 at 3:25 pm #202621I got a Roman self inflating 3/4 Moon Mat (matress) while in Coffs. Also grabbed an inflating pillow to rest the melon
Will give them a run on the upcomng Newy-Wauchope-Nundle trip ,,,,
