Rear Dry Bag
This topic contains 4 replies, has 0 voices, and was last updated by  Mick Pilgrim 14 years, 6 months ago.
  • #100458
    Mick Pilgrim
    [attachment=2808]BYBGDN1CA_zoom_1.jpg[/attachment]
    Guys
    Lotsa, Gavb and myself have been using ‘Beyond Castaway’ 60 litre dry roll bags for about 12 months now and they are holding up to the abuse quite well.
    Torpedo 7 has them on special again for $24.99 – a bargain
    Here is the link
    http://www.torpedo7.com.au/products/BYBGDN1CA/title/beyond-castaway-60l-roll-dry-bag
    Mick
    #208393
    Hi Mick,
    Can you tell me how long these bags are. Need to know if my tent etc will fit.
    Gaz
    #208395
    Puddles
    Features:
    Large and spacious waterproof bag
    1x welded front pocket with water resistant zip (L32cm x W30cm)
    600D Polyester
    TPU (Thermo-Plastic Urethane) coated to enhance durability and product life.
    Reinforced stitching at stress points
    Features an adjustable shoulder sling
    Top and side carry handles
    Specifications:
    Size (Folded): L62cm x H33cm x W30.5cm
    Size (Open): L62cm x H50cm x W30.5cm
    Capacity (large): 60L
    Weight (large): 1300g
    #208396
    Mick Pilgrim
    Hi Gaz
    I put my tent, ground sheet, chair and other gear in my bag
    The length of the opening of the roll top is about 600mm and you can fit items of about 700 long in the bottom of the bag. My chair is 700mm long when folded up and fits OK.
    We used Lotsa’s bag as an esky on the Nabiac Museum ride – a carton of bear and a bag of ice :laugh: :laugh:
    The bag holds quite a lot if you want or just roll it down smaller and strap it on
    I had a problem with the outside pocket dry zip not working properly when I got mine and I contacted Torpedo 7 and they could not replace it at the time as they had run out of stock. But they would refund my money if I wanted or give me a partial refund to compensate for the faulty zipper. I kept the bag and I dont use the outer pocket anyway. So their customer service seems pretty good.
    Mick
    #208394
    Thanks Mick,
    Will get 1 happening
    We used Lotsa’s bag as an esky on the Nabiac Museum ride – a carton of bear and a bag of ice (now your talking)
    Gaz
