Home › Forums › Product Reviews › Product Reviews › Rear sprocket, alloy or steel?
This topic contains 41 replies, has 0 voices, and was last updated by Trent 16 years, 10 months ago.
May 11, 2009 at 2:25 am #133486
put in gear twist the grip,let out clutch motor revs. nothing else happens.
normally good indicator
Or when you can see a distinct lean on the teeth of rear is good indicator to.
May 11, 2009 at 2:25 am #133487yeah, when its got less teeth than a rabbitohs supporter:laugh: :laugh: :laugh:
May 11, 2009 at 2:27 am #133488these guys do a goood deal IIRC after giving them a call he upgraded me to the hardened front and shipped for $220 or so which is good with an x ring chain.
Chain gang’s reputation is awesome but give them a call because they’ve been rumoured to have gone out of business on an off and might not be cutting their own sprockets anymore.
May 11, 2009 at 2:29 am #133489Boony wrote:
Quote:put in gear twist the grip,let out clutch motor revs. nothing else happens.
Its a bugger to get the front sprocket off once its at that stage unless you have a rattle gun :blush:
May 11, 2009 at 2:35 am #133490Or an Englishman eh Geezer Teeth:P
May 11, 2009 at 2:39 am #133492there is only one of them around here…….:laugh: :laugh: :laugh:
May 11, 2009 at 2:48 am #133491I run the standard IRC steel sprockets on the XR, the rear I have now has 6500km on it and is still good as gold. Actually it is only the 2nd rear sprocket it has ever had. The first one is still good only it was to small.
Another indicator of worn sprockets/chain is when you wheel the bike backwards (like off the trailer)is that you will hear a distinct clacking, not happy noise.
May 11, 2009 at 3:17 am #133497Thanks for the advice guys, as always very informative, not to mention entertaining. Based on this I have a few K’s left before I need a new set.
May 11, 2009 at 3:23 am #133504youll be right mate….it takes power to wear them out:laugh: :laugh: :laugh:
May 11, 2009 at 3:28 am #133505menace wrote:
Quote:youll be right mate….it takes power to wear them out:laugh: :laugh: :laugh:
Oh now I understand why my KTMs chain and sprockets hardly wore at all in 100 hrs of riding the ring off it.
Thanks Menace for clearing that up
May 11, 2009 at 3:34 am #133444Yes a Big Thanks from me too.
my bike now has some 13000 kms on it and to my knowledge it has not had a new chain or front sprocket on it, for any more than 1-2 thousand kms at most.
only changed sprockets to try different gearing combo’s.
May 11, 2009 at 3:38 am #133506Mr Blue wrote:
Quote:menace wrote:Quote:youll be right mate….it takes power to wear them out:laugh: :laugh: :laugh:
yes but a big wheel 50 pro senior dose not quite count:laugh: :laugh: :laugh: :laugh: :laugh: :blink:
May 11, 2009 at 3:47 am #133508xy-transit wrote:
Quote:yes but a big wheel 50 pro senior dose not quite count:laugh: :laugh: :laugh: :laugh: :laugh: :blink:The chain and sprockets on our 50 pro senior is the only thing I haven’t replaced.
there are 2 points there….
1) KTM factory sprockets and chains are just plain tuff:laugh:
2) you ride like a sloth:Pand for XYs sake
3)get some knobbies, then your drivetrain will wear;)May 11, 2009 at 4:10 am #133445Katie wore footy boots for the first 11000kms of her sporting life.
the shop that i had the 300 dramas with in their “wisdom” fitted the slicks for a “potential ” buyer.
i thought i may as well ware them out before fitting more suited tyres.
