Reed v/vs
Home Forums Tech Help Tech Help Reed v/vs
This topic contains 16 replies, has 0 voices, and was last updated by  dennis da menace 15 years, 3 months ago.
  • #99286
    Took Tims carby off and cleaned it out, everything looked very clean :(
    Emptied his tank and removed the v/v stem, Again spotless :(
    Just before we put the carby back in we decided to take a look at the reed v/v’s
    On removing the reed block we noticed this
    Bike had been playing up and would not rev cleanly
    I can only imagine that this is the problem :unsure:
    Has anybody else had similar issues??
    And what new v/v’s do we put back in a stock KTM 200
    From memory (25-30 years ago) we used to put stiffer reeds in, but I could be wrong.
    Any sugeestions??
    If not, I will stick to the original parts B)
    here you go Murph ;) http://shop.thumpertalk.com/catalogs/Parts_Unlimited_Offroad_2009/default.asp?p=801
    Give Sutto’s a call they have a sale on now for Old Bulls you may get a good deal B)
    Awesome Ollie
    I will chase some up :woohoo:
    mike
    Hey Murph. It will be a nice easy fix mate. My old 300 did the same thing but was not as noticable as Tims. Mine was more of a crack. :) I can’t remember the type I put in but they were after market ones and all was good again. :)
    #192589
    Cheers Dusty
    Read about the Boyesen 2 stage reed.
    I’m pretty sure thats what I put in my IT490 all those years ago
    Hope it fixes the fault
    +1 on the Boyesens
    If you wanted to spend a bit more, you could look at the V Force reeds.
    #192631
    Thanks Mick
    But I’m sure the boy will only spend what he needs to ;)
    Any need to change jetting, pretty sure I didn’t have with the 490??
    They look like carbon reads? I’m a little surprised they broke. Cracking more likely. Have heard of that happening in the past. Old reads we used to turn over to get more life out of them. Seeing as KTM has affection for V-Force reads I would be considering them first as a replacement Murf.
    #192632
    No real need to change any jetting specs Murph.
    #192634
    Cheers fella’s
    Will just see whats available locally and go from there :)
    probably useless information seeing smurph only wants to spend what is necessary.
    but a guy i was speaking to that has an 07 KX250, fitted Boysen ‘Rad Valves’ to it and he reckoned it was the best bang for buck he had spent on it. he said it increased his mid and top end power, but broadened the power out through the whole rev range.
    #192583
    Roy
    Murph/Dusty,
    How many hours did you blokes have on the bikes before it happened.
    Had the carby out the other day too and almost checked but thought it was just another thing I didn’t know anything about. Probably should of.
    #192584
    mike
    Hey Bundyroy. Mate I don’t know exactly how many hours but at first I just kept oiling up plugs every ride and than it was running like a dog like it had shit in the carb. It was’nt until I rang oldmate Pete the mechanic at Cessnock KTM who told me to check out the reeds. I put a new rings in aswell at the same time. At a guess mabye 300 – 400 hrs. It was a 99 model and i done it around 06 if I remember rightly. I rode heaps more than aswell, 3-5 hours every weekend mostly. The good old days :laugh:
    #192585
    Roy
    Thanks Dusty. Sounds like it is fairly easy to tell something is wrong and I’ve only got 150 hours up so far so touch wood might not have to worry for a while yet.
    #192677
    Tims bike just started running like crap
    We’ve owned it for a couple of years now and it has been a good reliable bike until now :angry:
    Had to order the Boyesen reeds in and they cost about 100 bucks ;)
    Will keep you updated when we fit them some time next week
