Home › Forums › Product Reviews › Product Reviews › Rev-Loc Clutch
This topic contains 15 replies, has 0 voices, and was last updated by Geoff Forshaw 12 years, 8 months ago.
July 3, 2011 at 12:26 am #100136
Hi Guy’s
I have been looking at buying an Auto Type Clutch and after doing some research I decided to buy a Rev-Loc Dyna Ring. Did my first ride today with it and did about 50km. It is awesome, the feel is just as per the original clutch and can be used in the same way.
It has plenty of bite and you wouldn’t even know that it was there only that when you do some tight singles and you need some rear brake to help a bit of turn-in you can stand on the rear brake and the bike won’t stall. Then get on the throttle and it just launches out of the corner. Also if you stop on a hill and want to slowly take off and get traction it is great for this too. The only thing at the moment is that it still has a little too much drag at idle but i will sort that out before the next ride. May be in a day or two. :whistle:Cheers,
LeftyJuly 3, 2011 at 12:32 am #204283Keep us posted on how it goes Lefty
Also how much did it cost and from where did you get it?
July 3, 2011 at 12:35 am #204285Sounds interesting lefty !
After following you on the birthday ride , how could YOU possibly have more drive out of a corner !!!
July 3, 2011 at 12:35 am #204288So Lefty it is the same as a Rekulse yeah? Whats the difference if there is one? Does it use the standard clutch plates or have a different setup?
Photos would help
July 3, 2011 at 12:39 am #204286Hi Adam,
It cost $395.00 plus delivery and i got it from Rev-Loc Australia. They are at Fairy Meadow I think from memory. :dry: They have a web site and Gerald is more than happy to help. They also take only about 15-20min to install.Cheers,
LeftyJuly 3, 2011 at 12:50 am #204287Hey TB,
It is similar to a Rekluse in the way it operates, however it replaces two of your fibre discs in the centre of your clutch stack. You use the std clutch basket and some of your steel plates. They supply you in the kit with 4 steel plates (which you must use). It also comes with a couple of spacers to put under your pressure plate to set up the correct height (gap) which is between 1.0 – 1.5mm. I have mine set up at 1.0mm which creates a little too much drag at idle at the moment but wiil sort it out by adding a spacer to increase the gap. The Rev-Loc then ramps up as RPM increase to take up the gap created on initial set-up.
I will get some pics organised a litte later.
LeftyJuly 3, 2011 at 12:53 am #204289Hey Nick,
The beauty about the Rev-Loc is that you have confidance in being up a gear in some places and the thing just hooks up with less wheel spin. :woohoo: :woohoo:
July 3, 2011 at 12:58 am #204284I see on their site you can roll start the bike?
July 3, 2011 at 1:17 am #204290Yes you can roll start their bike, i think hydraulic clutch only, but don’t quote me on that. You can purchase separately a cover which goes on the master cylinder with an adjustable screw which takes up the clearance in the clutch stack. Then once started you then de-adjust the screw to revert back to the Rev-Loc. Not sure if this is available in Australia though and for which bike but i am sure Gerald from Rev-Loc Aus will be able to guide you better on that.
Lefty
July 3, 2011 at 1:20 am #204291July 3, 2011 at 6:10 pm #204292Gent’s
I have had some more information sent to me regarding the manual (Cable) operation of the Rev-loc from the Australian distributor as Quoted below;
“I have my clutch gap set with my cable. If it is not trying to go I back the gap off. If it stalls I give it a bit more gap.
It will bed in over the first twenty hours and you will end up with a bit more gap.”
I must state that have nothing to do with Rev-loc either directly and/or indirectly and are just investing my experiences and knowledge with those who are thinging of investing their hard earned cash in a clutch of this type.
I must say that I have ridden Chris’ KTM400 fitted with a Rekluse and found it to be very good also. However i was prepared to spend around $400 for a Rev-loc Dyna Ring and not $900+ for a Rekluse to find it was not what I wanted or thought it would be. It will still take a little time to adjust to but as TB has mentioned to me, which i agree with, is that I will be using it as per normal and will only take advantage of it for rear braking and some tricky hill situations. Other than that it will be clutch as normal.
I will keep you posted as to how it ends up. From a value for money and durability point of view.
Lefty
July 3, 2011 at 6:20 pm #204313Gents,
I stated in post #107075 that the Rev-loc replaces 2 fbre plates in your clutch stack. I was incorrect it actually replaces 3 fibre plates and 2 steel plates and in approximately 11.5mm thick and placed in the centre of the clutch stack.
Sorry about that but i like to get the facts right. :huh:
Lefty
July 3, 2011 at 6:53 pm #204315Good report Lefty.
Will be interesting to see how it goes.
I tried to get some info on them back when I bought my rekluse. Wasn’t much around and they didn’t make them for my bike anyway.
Not a lot of info on the web site.
July 3, 2011 at 11:29 pm #204318Hi Guys,
Just thought i would post these links for some more info, for those who may be interested.
Watch Dyna Ring Install Video :: Jeff Slavens KTM300
http://www.youtube.com/watch?v=KzS44WEctuE&feature=related
Lefty
July 3, 2011 at 11:32 pm #204343Oops! Here is the first one.
http://www.youtube.com/watch?v=U7Ow-aWWuMA&feature=youtu.be
Lefty
