rim brand and pnch flats?
Home Forums Tech Help Tech Help rim brand and pnch flats?
This topic contains 10 replies, has 0 voices, and was last updated by  dennis da menace 15 years, 6 months ago.
  • #98857
    on the epic Glenmaggie ride i had pinch flats. ended up 2 fronts and one rear :unsure:
    i think i remember somewhere that one brand of rim could be more prone to pinch flats to another…
    is there any factual truth to this??
    the 640 has DID rims, i noticed most on the same rise would have had Excel, and had no problems riding over the same rocks etc. as i did with less pressure than i was..
    #186132
    You using the ultra heavy duty tubes Drew?
    #186134
    Drew I have DID rims on the 650 and have never had a pinch flat EVER.
    I have only ever had one flat and that was a hole through the side wall of a brand new tyre (12km’s old).
    I also run ultra heavy duty tubes and tend to steer around sharp looking rocks.
    #186135
    well i wasn’t running heavy duty tubes, the first front flat was replaced with a Kenda heavy duty i was carrying, it was flat also by the time i got back to the van.. i ordered these over the phone, when they arrived i thought to my self they aren’t much better than a STD. tube..
    i will be ordering some UHD tubes next pension day;) B)
    #186138
    ARe you sure they are pinch flats and there isn’t something sharp on the rim?
    #186139
    xy-transit wrote:
    well i wasn’t running heavy duty tubes )
    That pretty well answers your question there Drew
    What pressure did you put in it when you fixed it? Was only inflated with a can of finny leak or the likes I read. So not knowing the pressure you had in it would make it hard to say why you got a second flat. Maybe you pinched the tube when fitting or like Mick said there is something in there causing the flat.
    Bridgestone or Michelin ULTRA heavy duty tubes mate, Sutto’s has the Michelin’s on special if that helps
    You could get away with a little more pressure then most as well Drew being the fuller Aussie male
    that is something i’ll make sure of Mick when the tubes turn up and i fit them ;)
    now that you have reminded me, the first flat could have been caused by a broken spoke.
    however i got a flat with the front at Wombat last December and just assumes it was a pinch flat, as i could not find anything in the tyre or rim when i replaced the tube..
    #186142
    the rear was the one i used the motul brand compressor in a can on ;)
    the front was done with the camper’s 12v jobby.
    yeah thanks TB, i was going to ring Suttos’ thursday.
    #186143
    Heavy duty blokes like you and I need the Ultra heavy duty tubes mate :D :D :D
    #186144
    :laugh: :cheer: ;) 😆 :laugh: that’s the conclusion i’d come to as well, by the time i got back to the van.
    a big bike and a heavy rider was what i thought was most of the difference between the other rider/bike combos and I 😆
    #186145
    make sure you clean and dry the rims drew. at least the front as you will have to replace my temporary rim tape job. it probably lasted 2 minutes :blush:
    yeah, the first one was a broke spoke, i remember seeing Aido licking the nipple :laugh: :laugh: :laugh:
    and check the rest of the spokes by tapping them with the spoke spanner. you will hear the dull ones. give the m a nip up till they ‘ting’
