RMX kick starter
This topic contains 4 replies, has 0 voices, and was last updated by  terryjhaynes 14 years, 2 months ago.
  • #100869
    Trying to remove the kick start lever,, but after removing both the 12mm bolt and the screw,,,it’s lose but something is stopping it from sliding of the sharft. Dose anyone know the trick with this???
    Cheers Teza.
    #213746
    Teza you only need to remove the 12 mm bolt Its just probably a bit tight on the splines give it a bit of heat with a hot air gun and give her some gentle taps around the starter lever. You might be able to get a 3 or 4 jaw puller onto it as well ;)
    Cheers Teza.
    #213748
    Goodo, thanks Ollie,,,I didn’t want to force it ,just incase,,It could use a new one pretty soon i recon,,I remember reading on here that you could fit a DRZ one on,and is a better unit, but not too sure, cose they are $200. new from Sydney City Motocycles,,but anyway I’d rather pay that than be stuck in a gully with no kicker.
    Thanks Teza.
    #213749
    I got a DRZ one for mine and my Bro’s they do fit but you need to grind a fair chunk of metal off it for it to clear the cases etc. I havnt done mine as yet but my Brother has. I bought the DRZ Kickers from the states (and a YZ250 one for the Gasgas B) ) It was about $120 ea.
    OK man ,thanks for the info.
    cheers teza.
