Home › Forums › Tech Help › Tech Help › runs like train, turn it off and it will not fire again Husky 510 hot start, not
This topic contains 11 replies, has 0 voices, and was last updated by Crancky 14 years, 3 months ago.
November 23, 2011 at 9:55 pm #100746
any husky owners had a hot start issue with TE510 / 450, 08 models
Have worked through electrics (wires and connectors), maps, dash, turn it off or stall and it will not fire again,
let sit for 10 mins and it starts fine,
I have been able to get it to start if you sort of double/triple hit the starterbutoon, and it starts and runs like a dream
battery is 3 years old, always lived on charger,
voltage drops (at battery) to 10.5 ish when turning over, runs 14.2 when reving
13 ish when standingany ideas please guys and girls.
November 23, 2011 at 10:54 pm #212190Do they have the hot start button Crancky, I seem to remember Huskybloke always needed to use his when it stalled. The red knob next to the choke, on the bike that is, not Huskybloke
November 23, 2011 at 11:21 pm #212191crancky1,
i just bought a 08 510 and as the battery was stuffed put a new Shorai battery in it occasionally have to use the decomp lever to fire it regardless of charge as battery was new. It was a similar thing to how you describe hitting the switch a few times to get it to fire. This battery is rated at 220cca way higher than a stocker and occasionally still needs the de-comp to turn it.Could try kicking it around to TDC and then hit the button.November 24, 2011 at 12:03 am #212192thanks guys, the issue isn’t topdead centre problem, or decomp.
the engine turns over quickly and strongly,
just refuses to fire. when hot,was wondering if relays may loose their switching properties if old and heat effected,
November 24, 2011 at 1:59 am #212193This thread from CafeHusky mentions the same issue,might be some help.
November 24, 2011 at 10:22 am #212194Thanks 2 banger, i spent days trawlling though cafe husky, must have got a bit weed blind,
temp sensor looks like a definate culprit.November 24, 2011 at 12:41 pm #212214Temp. sensor…had a similar issue with my old 08 450, $30-$40 for a new one if memory serves me correctly.
Good luck !
November 24, 2011 at 4:34 pm #212195Had a yarn to R and D, they think it may be a decomp issue, bit of wear in the mechanism.
bike has done 7000k’s (all bush bashing)
November 24, 2011 at 8:46 pm #212196Cheers crancky1,
Lucked out on the search,some of those cafehusky posts are excellent,spent some time reading the tech stuff.That living with a 510 post is massive.good luck and let us know what you find,i might need to know myself one day.
November 26, 2011 at 10:35 pm #212197Update:
had a good ride today , but , still very difficult to hot start:pulled her apart tonight,
the start circuit relay has a wear mark from rubbing on frame / tank, and a little hole in case, this seems to be letting water and dust in,
replaced it and it now primes much better.
some thing for others to check !
i’ve got to do the valves as well, reckon that will bring some better starting
keep updating as I go.November 27, 2011 at 9:35 am #212299crancky1 wrote:Update:
keep updating as I go.Sounds like a good find, keep us posted
December 6, 2011 at 11:40 pm #212306update
relay was the hot start problem, all good now
valves spot on after 7000k’s unbeilevable! 😆the Power Com 5 and Auto Tune are working treat,
nice smooth bike, no flame outs, nice fat mid range -
