Seeing Your Way Clear
Home Forums Tech Help Tech Help Seeing Your Way Clear
This topic contains 3 replies, has 0 voices, and was last updated by  dennis da menace 15 years, 8 months ago.
  • #98760
    Given the drought conditions currently covering extensive tracts of Australia, dust is a common foe when you’re out riding, be it on the trails or at a motocross track. Attempting to follow someone through a cloud of billowing dust is frustrating, sometimes scary and often downright dangerous, while actually getting dust in your eyes will exacerbate the situation even further.
    If you come to find yourself in such a cloud, wondering which way is up and whether that shape you just noticed is simply dust or a looming fallen tree, the only preventative measure you can take is simply to back off and leave enough space between you and the bloke in front to let it clear – a tactic that’s not going to help much if you’re racing.
    But when it comes to getting dust in your eyes, there is an easy measure you can take to reduce the dust hazard. For the vast majority of goggles, you’ll see that between the foam padding that rests against your face, and the frame around the lens, there’s a gap of about a centimeter or less that’s covered in a very fine foam gauze.
    It’s fine so it can trap particles of dirt and dust, while still allowing the area ventilate, but no foam is fine enough to trap the really tiny particles you’ll encounter, and that’s where this tip can help. Simply purchase a bottle of baby oil from your local supermarket or chemist, and using your finger or a cotton bud apply a very light coating of oil to the foam. Hey presto, now even more dust should be kept at bay – which is a welcome relief for those sore, irritated eyes, and great news if you wear contact lenses.
    I also clean my goggles with Mr Sheen, the twin lenses I rain X also. All my goggles are stored in goggles bags and wrapped in tissues to prevent scratching from the strap rubbing against the lens in storage
    (This is a tip I use on some of my goggles, normally my Dragon goggles as they are the best sealing on my face and keep the dust out. My Scott twin lens are only used on wet days and the Oakley sets are carried as spares for any day. The tip I got from the insure my ride web site thanks saves typing everything out myself)
    Bob Dowsett
    My scott desert goggles are excellent for keeping dust out
    Drought is spelt with an O
    Get it right TB
    #184413
    Stuart
    Get it right TB
    Thought my Desert’s kept the dust out, until I did Finke, I don’t think any goggle would keep that dust out.
    #184443
    i dunno about the wrapped in tissue bit mate.
    tissues are made from wood, wood will scratch your lenses…
    believe it or not…
    ask any spectacle wearer ;)
