Shock Assembly advice
This topic contains 19 replies, has 0 voices, and was last updated by  Jeffrey Smith 12 years, 8 months ago.
  • #102353
    So I called in to Tekniks on Yesterday and picked up a heaviershock spring for the WR.
    Normally I just take the bike to a mechanic for anything other than a basic service or changing tyres, sprockets or chains. This time though I thought I would have a go and fit it myself but I have struck a bit of a problem.
    I thought it would just be a case of backing of the adjustment screws and swapping the springs around but it wasn’t quite that simple.
    Once I had the shock out of the bike I worked out that I had to take the lower part off to swap the springs so I undid the locknut then unscrewed the bottom piece and there was a thin shaft sticking out of the end. After I pulled the old spring off and grabbed the new one the thin shaft thing flew out and hit the wall and fluid started flowing out as well.
    So 2 questions
    a) I have lost fluid and need to replace it but how do I know how much
    b) I am not sure which way around the thin shaft was before it flew out. One end is pointed with a hole through it and the other end is rounded.
    and probably a third question, should I get the shock serviced while I have it out? The bike is 18 months old.
    #236228
    Richard W
    sounds deadly
    #236231
    take it back to technics i reckon get them to fix it
    #236232
    The lower spring retainer unseats once the preload is unwound and then can be rotated so that it can be removed. You have de-gassed your rear shock and that will mean taking it to a mechanic.
    If ever you are in doubt check on You-Tube first. Almost all basic maintenance jobs are on there.
    I am just getting nick some dinner ( he is back at the workshop building my Tenere engine ) I will tell him when I get back from up the street. :laugh:
    Nick Dole
    Ok, what you were supposed to do was undo the threaded pre-load collars at the top and then remove the c clip at the bottom to release the spring.
    Unfortunately you have unscrewed the clevis off the end of the shaft and the rebound needle has shot out under 150psi of gas pressure and hit the wall.
    Bring me the shock and the needle and the spring, i’ll give the shock a quickie service and get you on your way again…plus i’ll fit the spring!
    Will only take me 30 or 40 minutes if i’m not doing a full rebuild, it’s just strip the shock, reinstall the clevis and back together again…
    you are NOT the first, i get 2 or 3 every year…
    Ill be at work till 12 tonight, building TB’s engine or tomorrow….or Saturday…..
    #236229
    Ps Jeffro wrong end. Rumsoakedstudios has been employed to do videos on all these jobs by Nick but there just isn’t enough time in the day ATM :unsure:
    That’s impressive. It never ceases to amaze me how many different interpretations and methods people have on things. That’s human nature. How many thousand times I have done the same thing with other components. Bad luck is all.
    #236236
    I have been travelling to Sydney at least once a week for work for the past 12 months. This week was meant to be the last trip. I might have to see if I can scam one more work trip to save having to do it on my time :D
    #236242
    I just wish I had thought to look it up on you tube like Scott said
    #236243
    Unlucky Jeffro
    I have changed quite a few rear springs, so a quick question in “tech help” would of been the go.
    Hynd sight is a bugger of a thing. ;)
    Off to the shop for a regas, mate
    Sounds like Nick is onto it
    Nick Dole
    Shock is still full of gas, just no oil in it….
    The gas only pressurises the oil, it’s more oil than gas in there.
    I’ll be working almost all weekend if it’s any help….
    #236251
    test
    #236252
    I will probably be in Sydney Wednesday, I will drop it off and pick it after I have done my other jobs. Should be there around 10 and back by 3 I hope
    #236257
    Nick Dole
    Sweet, see you then.
