Shock removal from WR
Home Forums Tech Help Tech Help Shock removal from WR
This topic contains 9 replies, has 0 voices, and was last updated by  Bill 16 years, 9 months ago.
  • #96704
    I want to pull the shock out of my WR but it seems I have to pull the whole back end out to do it.
    Does anyone have any advice.
    What year stm, I have an 08 service manual I can look it up for you if you need me to.
    #141520
    Seat, side covers, sub frame, support on a centre stand, top and bottom bolts basically
    It is an 05 250
    #141524
    Fez
    I have a WR450F(S) factory owners manual with all that stuff in it. It tells you how to take out the rear shock. If you need it I will pm you my number so you can pick it up from Coffs if you need it.
    #141522
    Seat, side covers, sub frame, support on a centre stand, top and bottom bolts basically dont need a manual trust me
    #141523
    #141525
    Thanks for the help guys. Blue450 is sending me the manual on PDF and in the meantime I will take TB’s advice and just hook in, minus the TNT:laugh:
    #141560
    Can sometimes leave the sub frame attached at one end and pivot it and tighten the bolts to hold it out of the way
    Bill
    If you are replacing the lower bush can be done installed with link and swing arm removed but if not get the tee bars warmed up
