Silicone to stop bar vibes??
Home Forums General Bike Talk Silicone to stop bar vibes??
This topic contains 9 replies, has 0 voices, and was last updated by  Bruce Curtis 15 years, 8 months ago.
  • #98734
    I have been looking into set-ups for my DRZ for the ride to Camerons Corner and one guy says he fills his bars with silicone to reduce vibration , has anyone done this ? Does it work?
    #184060
    The Tenere’s come standard as does the BMW800 I think with bar weights. The weights that are standard on a Tenere are bloody heavy things that thread into a thread in the end of the bars. When the barbusters were fitted to my bike they did away with the weights. How well bar weights work I dont know. I have heard about filling the bars with silicon and lead in the end sections to achieve the same as the bar weights above. I will see if I can find where I read it :blink:
    I saw something on adding lead shot to the silicone so it’s suspended in the bars and gives a dampening effect to vibrations !
    I suppose a bit more weight up high on the DR won’t matter!!!
    #184062
    the bar snake liquid version looks to confirm that the silcone would work, might have to give it a go!
    #184070
    I would try and put some extra sort of weights in the silicon mix in the ends maybe ;)
    Let me know how it goes I am interested Nick
    either way works, it’s a distorted harmonics thing, two dissimilar materials and weight will help dampen different frequencies out.
    Did it before on a few of my bikes, especially the big 4Cyls they get a real fine annoying vibe up in certain rev ranges (primary & secondary harmonics), have used glue poured in bars, Aftermarket bar end weights and was toying with the idea of some sort of tube and compressed air at one stage, but decided that actually may amplify the vibes.
    Bruce
    #184107
    What type of glue did you pour into the bars Bruce?
    Ha ha :laugh: :laugh: :laugh:
    #184198
    not far off it TB, had few tubes of quik grip laying around work that needed using, so in they went.
    Makes fairly decent grip glue as well.
