Home › Forums › Off Topic, Hobbies, Fishing, Woodworking, Gardening and other G*y Activities › Off Topic, Hobbies, Fishing, Woodworking, Gardening and other G*y Activities › Site tweak?
This topic contains 65 replies, has 0 voices, and was last updated by David 16 years, 10 months ago.
May 29, 2009 at 2:35 am #137127
I have heard reports that some versions of wife 1.0 come with an add on called mother in law 0.666. Try to avoid this add on at all costs, as it will tend to override nearly all your commands and cause operating gliches with wife 1.0.
Should MIL 0.666 cause you any grief I recommend you try
Ctrl+alt+delete.May 29, 2009 at 2:40 am #137130Friday at work Ver1.1 a bit slow Boys:laugh:
May 29, 2009 at 2:47 am #137131I have also heard of people have success with wife V0.2 which is only available from the Philippines. It is said to be user friendly and much more compliant than the versions available here.
May 29, 2009 at 3:16 am #137133micknmeld wrote:
Quote:I have also heard of people have success with wife V0.2 which is only available from the Philippines. It is said to be user friendly and much more compliant than the versions available here.But sometimes those Blokes have insufficent harddrives or are even limited to 3.5″ floppys to consistently satisfy the demands of domestically produced versions, this may lead to Wife 1.0 root files being totally corrupted by Neighbour 2.0 or Workmate 2.2, so instead of subscribing to another domestic product they at great expense import said Wife V0.2 which may or maynot have had many foriegn software developers using assorted plugins before it is installed here or could be infact another sort of programme altogether then being retweaked by removing plugins which will leave serviceable gaps in the software, then gets reassigned a new designation and no-one is any the wiser, particularly the end user.
May 29, 2009 at 3:49 am #137135GOLD mr BLUE!!! Absolute gold.:laugh:
May 29, 2009 at 4:03 am #137140WTF are you lot on about this time
get out of the sheds or open a window for ventilation the fumes are effecting your heads:dry: :huh: :blink:
May 29, 2009 at 4:06 am #137141Boony wrote:
Quote:WTF are you lot on about this timeget out of the sheds or open a window for ventilation the fumes are effecting your heads:dry: :huh: :blink:
Just let it go throught to the keeper if you can’t keep up Boony.You’ll be right mate.
I suspect he’s trying to run a modern version on an ancient 3.5″ floppy that works sporadically.
CPU needs replacing, doesn’t process quick enough, either that or he has too big a harddrive and all his resources are wasted trying to run it.
Well Boony, computers are like sex but in reverse. = a computer you put the software into the hardware!
May 29, 2009 at 4:20 am #137146I think Boony’s problem could be partially resolved by the installation of A-Clue 1.1 which is a great resource, and overwrites any of the ongoing conflicts caused by the 3.5″ floppy. If the problem is related to his harddrive though, I suspect it may be more cost effective to completely format Boony 1.0 and try a new operating system with more resources.
May 29, 2009 at 4:36 am #137147Man you guys are cracking me up, don’t know how you hold down full time jobs.
May 29, 2009 at 4:38 am #137148ECKS-Man wrote:
Quote:I think Boony’s problem could be partially resolved by the installation of A-Clue 1.1 which is a great resource, and overwrites any of the ongoing conflicts caused by the 3.5″ floppy. If the problem is related to his harddrive though, I suspect it may be more cost effective to completely format Boony 1.0 and try a new operating system with more resources.KEEPERS BALL
May 29, 2009 at 4:50 am #137149Boony wrote:
Quote:ECKS-Man wrote:Quote:I think Boony’s problem could be partially resolved by the installation of A-Clue 1.1 which is a great resource, and overwrites any of the ongoing conflicts caused by the 3.5″ floppy. If the problem is related to his harddrive though, I suspect it may be more cost effective to completely format Boony 1.0 and try a new operating system with more resources.KEEPERS BALL
Yep Corrupted system here, now he thinks he’s a gaming machine plaing soccer no less, probably an 1980’s Atari (same design era as the Zook Eh?)or commodore 64 reckon he needs a reboot and replacing that 3.5″ floppy with an external Stick that works.
May 29, 2009 at 5:21 am #137150
AnonymousAhhhh….the Commodore 64! I had one of them, we upgraded to an Amiga 128
May 29, 2009 at 5:48 am #137156Oi, you blokes. You are very funny! I’ve just read through all your ramblings. The ‘double onton’ (or however you spell it) is brilliant. I was giggling like a schoolgirl. How good is it to finish a days work, come home, crack a beer/ rum and read through some light, meaningless funny stuff. Well done, Keep it up!
Crash -
