Site tweak?
This topic contains 65 replies, has 0 voices, and was last updated by  David 16 years, 10 months ago.
Viewing 6 posts - 61 through 66 (of 66 total)
  • #137233
    You asked for it or maybe not!
    I’m currently running the latest version of GirlFriend and I’ve been having some problems lately. I’ve been running the same version of DrinkingBuddies 1.0 forever, as my primary application, and all the GirlFriend releases I’ve tried have always conflicted with it.
    I hear that DrinkingBuddies won’t crash if GirlFriend is run in background mode and the sound is turned off. But I’m embarrassed to say I can’t find the switch to turn the sound off. I just run them seperately, and it works okay. GirlFriend also seems to have a problem co-existing with my Leisure 3.1 and QuietTime programs, often trying to abort them with some sort of timing incompatibility.
    I probably should have stayed with GirlFriend 1.0, but I thought I might see better performance from GirlFriend 2.0. After months of conflicts and other problems, I consulted a friend who has had experience with GirlFriend 2.0, and eventually it would require a Token Ring to run properly. He was right-as soon as I purged my cache, it uninstalled itself.
    Shortly after that, I installed GirlFriend 3.0 beta. All the bugs were supposed to be gone, but the first time I used it, it gave me a virus anyway. I had to clean out my whole system and shut down for a while to re-check my hardware.
    I very cautiously upgraded to GirlFriend 4.0. This time I used a SCSI probe first and also installed a virus protection program. It worked okay for a while, until I discovered that GirlFriend 1.0 was still in my system. I tried running FirlFriend 1.0 again with GirlFriend 4.0 still installed, but GirlFriend 4.0 has a “feature” I didn’t know about that automatically detects the presence of any other version of GirlFriend and communicates with it in the background in some way, which results in the immediate removal of both versions.
    The version I have now works pretty well, but there are still some problems. Like all versions of GirlFriend, it is written in some obscure language I can’t understand, much less reprogram. Frankly, I think there is too much attention paid to the look and feel rather than the desired functionality. Also, to get the best connections with your hardware, you usually have to use gold-plated contacts, which is very expensive. And I’ve never liked how GirlFriend is totally “object-oriented”, as that interface is sometimes cumbersome and even counter-intuitive.
    A year ago, a friend of mine upgraded his version of GirlFriend to GirlFriendPlus 1.1. which is a Terminate and Stay Resident version of GirlFriend. To his dismay, however, he discovered that GirlFriendPlus 1.1 expires within a year of the upgrade, if you don’t upgrade AGAIN to Fiancee 1.0. So he did, but soon after that, he had to upgrade YET AGAIN to Wife 1.0, which he describes as a HUGE resource hog.
    It has taken up all his space, so he can’t load anything else. In fact, it has even automatically deleted several of his other programs to make room for itself, not the least of which was DrinkingBuddies 1.0 on a network with several of our mutual friends, and now he can’t even connect anymore!
    He told me that one of the primary reasons he decided to go with Wife 1.0 was because it came bundled with FreeSexPlus, which sounded great. Well, it turns out the resource allocation module of Wife 1.0 sometimes inexplicably prohibits access to FreeSexPlus, particularly when he starts the new Plug-Ins he wanted to try. Also, for no apparent reason, the OralSex 1.0 module that worked fine in his previous versins of GirlFriendPlus and Fiancee, stopped working the instant the upgrade to Wife 1.0 finished installing.
    On top of that, Wife 1.0 must be running on a well warmed-up system before he can do anything with the FreeSexPlus module. This warming up process requires him to run an antiquated version of ForePlay Beta, which has an agonizingly slow interface, and which has an unfortunate tendency to crash, requiring a cold reboot to his system. The real insult to injury however, is that even though he did not ask for it, Wife 1.0 came embedded with MotherInLaw 2.0, which has an irritating automatic pop-up feature he can’t turn off.
    I told him to try installing Mistress 1.0 (which I had heard works great in such situation), but he said he heard if you try to run it without first uninstalling Wife 1.0, Wife 1.0 will delete all of your MSMoney files before doing an uninstall of itself. Then Mistress 1.0 won’t install anyway because of insufficient resources.
    Please help me Bob, I don’t know what to do. Since the initial release, I have had nothing but problems.
    I’ve heard that I would really like the CoolGirlFriend 1.0 Deluxe Upgrade (which is supposed to come bundled with a completely functioning version of FreeSexDeluxe), but that release is no where to be found-not even the Beta version! That release is also supposed to come with it’s own resource management module seamlessly layered in, so it won’t conflict with any of my other programs (barring previous versions of GirlFriend, which I would happily delete!).
    Please Advise.
    WIFE FOR WINDOWS Vsn 1.0
    Last year a friend of mine upgraded Girlfriend 6.0 to Wife 1.0, and found that it is memory hungry, leaving very little system resources for other applications. He is only now noticing that wife 1.0 is also spawning Child Processes, which are further consuming valuable resources. No mention of this particular phenomena was included in the product specification, brochures or documentation, although other users have informed him that this is to be expected due to the nature of the application. To add to the dilemma, Wife 1.0 also installs itself in such a way that it is always launched when the system is initialized, where it can monitor ALL other system activity. In so doing he is finding that some applications such as Poker Night 10.3, Beer Bash 2.5, and Pub Night 7.0 are no longer able to run, crashing the system when selected (even though they always worked fine before). When installed, Wife 1.0 automatically attaches undesired plug-ins, such as Mother-in-Law 55.8 and Brother-in-Law Beta 1.5 release. As a consequence, system performance seems to deteriorate with each passing day. Some features he’d like to see in the release of Wife 2.0 are:
    A “Don’t remind me again” button
    A mute facility minimize button
    An install shield feature that allows wife 2.0 to be installed with the option to de-install at any time without the loss of cache and other system resources.
    I myself decided to avoid all of the headaches associated with Wife 1.0 by sticking with Girlfriend 2.0. Even here however, I found many problems. Apparently you cannot install Girlfriend 2.0 on top of Girlfriend 1.0. You must de-install Girlfriend 1.0 first. Other users say this is a long standing bug which I should have been made aware of. This may be actionable misrepresentation. Apparently all the versions of Girlfriend have conflicts over shared use of the I/0 port. You think they would have fixed such a stupid bug by now. To make matters worse, The Uninstall Program for Girlfriend 1.0 does not work very well at all, leaving undesirable traces of the application in the system. Another annoying problem with all versions of Girlfriend is that they continually pop up annoying messages about the advantages of upgrading to Wife 1.0.
    ******* BUG WARNING *******
    Wife 1.0 has an undocumented bug. If you try to install Mistress 1.1 before de-installing Wife 1.0, Wife 1.0 will delete MS Money files before executing a self-deinstallation. Then Mistress 1.1 will refuse to install, claiming insufficient system resources.
    ******* BUG FIX *******
    To avoid the above bug, try installing Mistress 1.1 on a different system, and never run any file transfer applications such as LapLink 6.0. Also beware of similar shareware applications that have been known to carry viruses that may affect Wife 1.0 Another solution would be to run Mistress 1.1 via a Use Net provider under an anonymous name. Here again, beware of the viruses which can accidentally be downloaded from the Use Net.
    #137251
    Chris, There are people that have gotten Girlfriend 1.1 to successfully interact with Girlfriend 2.0 and made some very interesting video tutorials of said interactions.:blink:
    #137252
    I have found success lads,
    Its easy and you need to go through a re-adjustment period but at the end of it you wont understand what the fuss was all about with conflicts.
    There is this radical program called Adrenaline Plus 1.1, it allows you to finally concentrate without the hassles of all the wife or girlfriend apps from the past, there is an endless amount of variations and plug ins that come with this to allow expansion into many diverse fields, Drinking1.1, racing 2.1, as well as Anything you want 1.1, and I mean anything- no conflicts whatsoever, to further the removal and eradication of the bad rouge apps coming back the latest Wanking for the pro1.1 is a must, and once installed you wont have any of the expense, hassle or constant prompt denials of all the other flashy expensive Girlfriend?wife combos, as a matter of a fact it is fully compatible with everything you interface with.
    So the winning combo is Adrenaline Plus 1.1, and Wanking for the Pro1.1, (one of the essential upgrades for wanker is another program called Better Hearing 2.6, its a must!!!
    :laugh: :laugh:
    #137253
    conversely I have heard of one that got Wife V 1.0 to willingly interact with Girlfriend V 2.0 and before you could blink they had locked him out of the system and found they could interface without him, he is now in the market for Girlfriend Basic V3.0 that is only licenced for one user.
    #137308
    Dave I have tears rolling down my cheeks. That has to be up there with the funniest post ever. You and MR Blue have excelled yourselves in this thread.. Closely followed by Chris’ offering..LMFAO
    #137364
    :laugh: :laugh:
    What do you mean Funny…I was being serious;) :) :laugh: :unsure: :ohmy: :blink: :blink: :blink:
