Spark Plug numbers and letters
Home Forums Tech Help Tech Help Spark Plug numbers and letters
This topic contains 7 replies, has 0 voices, and was last updated by  Steve Wyeth 13 years, 4 months ago.
  • #102034
    Darren
    Getting a spare plug has been on my list for ages as a “To-Do” … was just down at SCA getting some other stuff and thought I’d look for the plug for my bike at the same time. Well, other than there being sh*tloads of them, scanning through looking for mine “NGK R BR7ES” I saw every friggin thing but! Even BR6ES and BR8ES, and some that were “Iridium” with BR6EIS and BR8EIS with a 10x (approx) price tag.
    So, my question is what does one-up and one-down in number indicate? Also, are the premium ones worth it? What’s the diff?
    Thanks in advance
    Razzle
    #231900
    Good question their Razzle , I just thought it was a part number and didn’t mean much but maybe it does ??
    I used an iridium plug in my Tenere with success but seemed to get no life out of them in the Crf ??
    Ok I’m no expert but I was led to believe the number is a heat range with a lower number being a hotter plug.
    #231906
    Yep its the heat range and using the wrong one can lead to destroyed pistons in 2 stroke engines. No doubt it does damage to 4 strokes as well.
    Iridium plugs I can’t answer on, other than they last no longer in my sons KX65 than a standard one.
    #231913
    I had a bizarre experience with an iridium plug. I went to buy a replacement and the shop offered me the option of iridium at $25 dollars more ( so i bought it) and my bike hated it. It would miss and run rough so I stuck the old cheapie back in and it purred like a kitten. Maybe a dodgy one but I have since just gone the $6 one and had no issue.
    OK, have done some research. The heat range is determined by the length of the insulator protruding around the electrode. The shorter it is the less insulation and therefore the hotter the spark is. This will lead to pre-detonation if used in the wrong situation. Too cold will lead to fouled plugs.
    Iridium plugs use iridium for the electrode. It can be made thinner than a conventional material and also have a squarer edge to improve the ability to make a good spark for longer.
    The numbering system varies from manufacturer to manufacturer. It reflects the heat range of the plug.
    #231955
    Darren
    Thanks Jimmy
    Sounds like it’s just best I look for the correct “number” plug and stick to the standard (and not expensive) one.
    Razz
    #231969
    Steve Wyeth
    Razz, stick with the stock plug and gap it to 0.60mm. The Iridium are a waste and time and money for our bikes. A nicely jetted bikes runs sweet as a nut on the stock plug. I tried the Iridium and a BR8 but ended up back at the stock plug.
    Always carry a spare in your camelback too. I never needed one but you just don’t know……
