Spongy brakes
Home Forums Tech Help Tech Help Spongy brakes
This topic contains 7 replies, has 0 voices, and was last updated by  Anonymous 16 years ago.
  • #97859
    Anybody out there know if it is alright to use DOT 4 brake fluidinstead of the recommended DOT 5.1 for a KTM
    The manual says not to use DOT 5 as it is a silicane based product and will damage the seals. I think I have used DOT 4 in the past but can’t remember :blush:
    Any help would be much appreciated as I have to get on top of this brake issue before tomorrows ride :unsure:
    Murph the surf
    #167507
    Ask Dick!! :laugh:
    Dot 4 is fine
    Thanks Ollie
    Just wanted to be sure
    Where is Dick :unsure:
    Me thinks he does not own a KTM
    Or maybe he is not the “quick Dick” that he has made out :silly:
    DOT 4 is okay. My manual(s) state that DOT 5.1 or DOT4 should be used.
    #167517
    Cheers Moto
    #167516
    Murph the surf wrote:
    Thanks Ollie
    Dick says relax Murph you old hippie
    Dick would like to apologise for his absence but Dick sometimes has shit to do
    Dick says Yes, as the others have said, you can run either DOT4 or DOT5.
    Do not mix them though and certainly clean out the lines first!
    The difference between the DOT ratings are simply their boiling point ranges.
    About the only time I can think of needing a higher DOT rating is when you are racing. Brakes/Fluid tend to get very hot then.
    #167549
    Aha witty Dick or to put it another way Dickwit
    Thanks Dicky
    Dick’s says you are welcome Murph there is more to it but the basics are that
