Home › Forums › The Adventure Moto Riding Forum › Dual Sporting / Adventure Riding › GPSs / Maps / Software and Hardware › Spot 2 or Spot Connect??
This topic contains 65 replies, has 0 voices, and was last updated by Greg 12 years, 1 month ago.
August 2, 2013 at 10:17 am #235928
Yeah mate,
The Spot sends a blip to the satellites every 10 mins (as long as it has coverage) and joins each blip with a straight line. It does not follow track line like a GPS would normally.August 2, 2013 at 10:31 am #247481Hey eagle
I’m heading down to the central Coast in the morning to see my Dad – here’s my link – interersted to see if it works ok.
http://share.findmespot.com/shared/faces/viewspots.jsp?glId=0fTNmhiDI0yLdpjJ1hthEVf547RgedW9v
Linz
August 2, 2013 at 10:35 am #235929I`m flying to Brisvegas mid morning mate,,
Will have a look later in the day when I get thereCheers
August 4, 2013 at 1:02 am #247483OK so I have finally set up my spot connect. Wasn’t to much of a drama. I even found a promo code online for free tracking for 12 months and saved myself $50USD. Although it had to process my credit card number twice for some reason. Anyway I decided to give it a test by sending a predefined message.
Well the wrong message came through to my wifes’ phone. Instead of
“All OK – Just got here”
She received
“Broken down – call when I can”
So as you can see I was a little surprised. Anyone else had the wrong message come through on their spot before. I’m now sending a typed message to see if that works.
August 4, 2013 at 1:06 am #247517D-Rally wrote:OK so I have finally set up my spot connect. Wasn’t to much of a drama. I even found a promo code online for free tracking for 12 months and saved myself $50USD. Although it had to process my credit card number twice for some reason. Anyway I decided to give it a test by sending a predefined message.Well the wrong message came through to my wifes’ phone. Instead of
She received
No mate, maybe have them in the wrong boxes or did it wrong on your app. Try again, practice makes perfect :laugh: or ring if you get stuck
August 4, 2013 at 1:31 am #235930Check these images TB. I might do another one today and see if it does it again
August 4, 2013 at 1:33 am #247518BTW – the custom typed message worked fine.
August 6, 2013 at 8:19 am #247302Trailboss wrote:plindz wrote:Hi TBAny chance of a pic – :unsure:
Linz
Yes mate of course but you will need to wait until Saturday I am away mate
Hey TB
How’s that pic coming along ??
I found something on ebay that looked ok for $20 but they wanted $50 to post it – that’s not gunna happen
Linz
August 6, 2013 at 9:03 am #247600plindz wrote:Trailboss wrote:plindz wrote:Hi TBAny chance of a pic – :unsure:
Linz
Hey TB
Linz
Forgot will do it tonight mate
August 7, 2013 at 10:26 am #247482August 7, 2013 at 10:38 am #247652Thanx (it’s important you get your beauty sleep)- give’s me an idea as to what to do.
Shame they don’t have an actual holder designed for that type of application. Maybe worth making one – could make a $mill :whistle:
August 31, 2013 at 9:46 am #247653Hey TB
Tried out the SPot last weeekend – thanks for the pics of how to attach to backpack strap. Couple of questions
The spot kept disconnecting from my iphone (bluetooth) even though not more than 300mm apart
I sent my spot address to mate but it showed on my link that the spot was not activated even though i set it up as per instructions and set it on track via my iphone – whats the deal??Linz
September 10, 2013 at 5:29 am #235931Hey Linz,
Check if you hadn`t deactivated the page.
*Hit the “”SHARE tab at top of page
*Then click “Edit/manage Shared page”
*Highlight the page you want in the small box in left hand column (I have multiple ones setup)
*Then there is an ACTIVATE or DEACTIVATE button at top of screen.This may help :whistle:
September 10, 2013 at 8:33 am #249512Thanx mate – that should fix it :woohoo: Need a bit of time on these thing to work out properly
September 10, 2013 at 8:45 am #235932Well it might fix it,,, if that was actually the problem :laugh:
Not sure on the disconnecting Bluetooth drama.
Good Lithium betteries are a must and make sure they are fresh ones at the start of a multi day ride (and carry spares just in case) :whistle:
I presume the connect runs the same batery setup ??? 3x AAA LithiumsIf you have any more probs with it, give me a yell and I`m sure we can sort something out after work one arvo
