sprocket sizes
Home Forums KTM Bikes KTM Bikes sprocket sizes
This topic contains 9 replies, has 0 voices, and was last updated by  murph the surf 14 years, 3 months ago.
  • #100849
    craig evans
    im just wondering what sprocket sizes and brands people are running on there bikes for general ,single tracks and maybe for enduro’s ,im only running standed at moment but i want to get some ready when i wear these standed ones out iv got a 2012 ktm 450 exc-f and also what tyres you running also that seem to be doing well
    #213475
    Hey Wolfie
    Those two questions are as subjective as religion and politics. :cheer:
    Gearing wise try 14/52 for singletrack and work your way to the sweet spot from there. I run 13/51 but I am on a 250f. Remember 4 in the back equals 1 on the front but smaller fronts will free the donk up down low.
    As for tyres I reckon the Pirelli MX Extra is an excellent starting point. If you can go softer try a Geomax or S12.
    #213476
    craig evans
    thanx for that i will try a few combos but if i can get a starting idea it can save a lot of guess work when you get a new different bike to normally have been riding or getn back into it after being out for a while thanx alot , what an excuse to get out riding lol
    #213478
    Adrian Gale
    The lads on KTM 450’s that I ride with run 14-51 or 52. They seem to be happy with that.
    #213477
    craig evans
    thanx galeyktm300 will try them
    #213483
    Standard is 13:52, I think 14:51 will be too fast for single track. (you will be in 1st gear all day)
    Torpedo7.com has Dunlop Geomax tyres cheap.
    #213485
    Run the biggest front you can you will get longer chain and sprocket life. As LC said but going to a14:51 from the 13:50 would make a fair difference. I am pretty sure Sutto’s change the gearing when they assemble the bike and do the pre delivery ( thats why they have the box of ADR sprockets at the front counter for adv bikes :laugh: ) Put some miles on that and check it maybe it will suit you then when they are worn out get the same size but better quality chain and sprockets. As for tyres like the king and LC said they are the popular brands and with the relationship you have with Sutto’s already and being an Old Bull Scotty will more than look after you and they will fit them for you as well
    Have fun
    Gearing is hard to advise as it’s a personal thing. Run the gearing that Suttos set up you on the trails you like to ride for a while. If you find that you can’t get the engine in a sweet spot for you and your always switching between say 2nd and 3rd then a larger rear sprocket might be the go to stay in 3rd longer.
    STM is on the money with the MX Extras. I run them on the rear last year and liked them until they wore down past half way then they become a bit unpreticable. I had a Pirelli Mid Soft on the front which worked well too.
    #213488
    Evan
    I use a 51 on the back , you can use 2 gear alot more on hills and singles.
    I tried a 52 and it was terrible , I found for every tooth on the back you loose about 12ks per hour in top speed.
    Max speed with a 52 was about 85/95ks , and everytime you backed off the throttle you almost went over the bars.
    #213489
    Hey Wolfie
    I own a KTM500
    Pretty sure it came standard with 13-50.
    I didn’t like it. Changed it to 14-50 and loved it.
    The 500 has plenty of grunt to pull a higher ratio
    We ride mainly singles and big rocky mother hills and it seems to be a good ratio
    The 13-50 ratio had me changing gears to often
    Murph the surf
