Stiffing up the forks on the DRZ
Home Forums Mud n Tar Suzuki Bikes Forum Mud n Tar Suzuki Bikes Forum Stiffing up the forks on the DRZ
This topic contains 100 replies, has 0 voices, and was last updated by  Dean 16 years, 6 months ago.
Viewing 11 posts - 91 through 101 (of 101 total)
  • #149228
    mongo wrote:
    boulder wrote:
    Adrian wrote:
    My forks are at Teknik as we speak Adrian, i picked up a rear spring from them and fitted it myself today $189.00. I.:)
    i ordered a rear spring today from teknik after reading this post $180.70 delivered to near newcastle..
    i’m not very very mechanically minded are they hard to fit,,
    Don’t think it would be terribly difficult MONGO maybe one the guys that have done it can share some info Guys?
    #145559
    I have sent a PM Chris.
    #149289
    mick
    how do i actually take the spring off the strut ??? has it got anything to do with the screw,
    #149869
    No you punch the flange to expose circlip have pm a pic for you. You will have to set the sag on your bike once you have fitted your new spring you will need two people to do this.
    Give me a call if you get stuck.
    #145560
    mick
    the newer models must be different,,a mate came around and we couldn’t find a circlip anywhere.
    so with sum deliberating we stuck it in a vice and screwed it apart.. and it worked good till the oil came spurting out….got the new spring on..just gotta get it refilled now….
    anyone have a rough idea what the cost of that would be ….
    #145561
    As far as I know the shock is the same on later models, the seat at the bottom of shock as in picture can be a bit hard to move and requires some love with a drift. I think you may have to take shock to a bike shop to have oil filled and have them check it out.
    #149929
    mick
    must be different coz there definetly wasn’t a clip there…and the ring doesn’t come off like you see in the picture its all one piece and the metal isn’t a shinee type like the pic
    #149925
    you will be lucky to get out of it for under $200
    oil = $30
    Regas = $40+
    labour = 1.5hrs at approx $85 $130
    but it will be done right and you wont have to worry about it throwing you in the scrub
    ok..just wound the large nut on the rear shock down 5 turns to assist with rear shock sag, see how it helps now the fronts all new and done, still have the clickers to play with on the front as steve set them on factory settings.
    #149933
    mick
    oil = $30
    Regas = $40+
    took the shock in this arvo $150 of which $120 was labour…told him what i done and said i would had to get the grinder onto the collar..
    #150086
    Very Good;) I wasnt to far off the mark,must have got your gas for freeB)
